Optimizing ObjectMeshSkinned loading
I try to optimize the creation/loading of our "avatar" at runtime.
As I am working on a online game it can happen that the game need to create more than one "avatar" at the same time.
So I made some "performance" test and for example creating 100 avatars took approximately 5 seconds.
Instead of loading the node (which contains the ObjectMeshSkinned) and loading the skinner script each time I try to preload/clone them.
But at the end it still too long.
Here is my code
        Avatar(ObjectMeshSkinned preloadedMesh, Unigine::Skinner::Skinner precreatedSkinner, Unigine::Schemer::SchemerScript preloadedScript)
            Node clonedNode = preloadedMesh.clone();
            _mesh = class_cast("ObjectMeshSkinned", clonedNode);
            class_append(_mesh);
            _skinnerMesh = new Unigine::Skinner::SkinnerMesh(precreatedSkinner, _mesh);
            _skinnerMesh.setScript(preloadedScript);
            initialize();
After commenting lines to find which line took all the time if found that it is
I take a look at the code of skinner_mesh.h and I see that the script is compiled.
Is there a way to preload and precompile a script and then to clone it ? So I have not to compile the script each time I create an avatar ?
Thanks.
Hi Nicolas,
unfortunatelly, there is no such opportunity for now, you have to create new expression instance for every skinner mesh object.
ok,
so the only solution I have if a want to optimize the create of many skinner mesh at the same time is to have a "pool" of object precreated and then take object from the pool instead of creating new one ?
Yes, this is a fine solution. It is better to wait on world loading, instead of realtime lags =).
