Michel Posted March 29, 2016 Share Posted March 29, 2016 In 2.1, it used to be possible to bind different textures to different shader stages but the same texture unit. For example: <?xml version="1.0" encoding="utf-8"?> <materials version="2.1"> <material name="test_mat"> <texture unit="0" name="tex0" shader="vertex" pass="ambient"/> <texture unit="0" name="tex1" shader="fragment" pass="ambient"/> </material> </materials> tex0 and tex1 could be different textures in the vertex and fragment stages. In 2.2, the same material would look like this: <?xml version="1.0" encoding="utf-8"?> <materials version="2.2"> <material name="test_mat"> <texture unit="0" name="tex0" shader="all" pass="ambient"/> <texture unit="0" name="tex1" shader="fragment" pass="ambient"/> </material> </materials> However, this no longer works, because since the texture "tex0" that should be bound to the "all" vertex stage is overriden by the bind of "tex1" to the fragment stage. I have a material that has 19 textures. The texture array functionality in 2.2 is not exposed, so I consider this regression a bug, since it is no longer possible for the material to work without major refactoring. Link to comment
silent Posted March 29, 2016 Share Posted March 29, 2016 Hi Michel, This is not a regression, we've slightly changed how engine handles textures internally. Right now it is not possible to have more than 16 textures per program (vertex / fragment / eval in DX11). If you can provide us a test scene that illustrates issue - we will try to find optimal solution to restore that kind of functionality. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
