teplov.ivan Posted March 25, 2016 Posted March 25, 2016 Hi! I want to use orthographic camera mode for rendering transport scheme (because when it's used perspective mode some buildings in city model cover scheme) but I have not find this property in camera settings in Unigine editor (Unigine ver. 2.2). How can I switch on orthographic mode? And how can I render scheme (scheme is single node) always over all?
necris Posted March 28, 2016 Posted March 28, 2016 Hi, Ortho projection for editor camera was temporary disabled in Unigine 2, sorry for that. It will be fixed in 2.3 update. Sorry for the inconvenience caused. And how can I render scheme (scheme is single node) always over all? There are several answers. Please describe your issue and expected result in more details. Transport scheme - what kind of node and material you use? Do you need translucent view or something else. Simple test scene or at least screenshot would be useful for us.
teplov.ivan Posted March 28, 2016 Author Posted March 28, 2016 Hi, Ortho projection for editor camera was temporary disabled in Unigine 2, sorry for that. It will be fixed in 2.3 update. Sorry for the inconvenience caused. Oh, it's a pity. And when 2.3 update will release? There are several answers. Please describe your issue and expected result in more details. Transport scheme - what kind of node and material you use? Do you need translucent view or something else. Simple test scene or at least screenshot would be useful for us. Hm, let me explain on this example (on the screenshot): I need that white plane overlaps all geometry in scene. Polygon offset does similar effect, but I need that this effect isn't limited by distance.
necris Posted March 30, 2016 Posted March 30, 2016 Hi, Sorry for late reply Oh, it's a pity. And when 2.3 update will release? ETA - end of june. I need that white plane overlaps all geometry in scene. Polygon offset does similar effect, but I need that this effect isn't limited by distance. Please check sample scenes attached overlap_sample.zip. scene_simple: expected result achieved by using visualizer.renderSolidObject() method. Besides, we disable visualizer depth test ("show_visualizer 2" command). The problem is that you can't set texture for object (using this method) scene_advanced: (preferable) We add new WidgetSpriteViewport where only objects with exact viewport mask (0x02) should be rendered.
teplov.ivan Posted April 25, 2016 Author Posted April 25, 2016 Thanks for your help, it's very useful. I decided to use a WidgetSpriteViewport, but it was reduced performance (my scheme is pretty big): I had lost 3-5 fps and when I dragged camera fast (camera's velocity about 1000-1500) the scheme had moved with inertia. Also, my scheme renders overlap user interface (see screenshot). How may I solve these problems?
sebastianbah Posted April 26, 2016 Posted April 26, 2016 Hi, Could you please send us a minimal test scene? I'm afraid it's difficult to give any specific advice without the scene. Thanks!
teplov.ivan Posted April 29, 2016 Author Posted April 29, 2016 Here is archive with test scene in which simulated conditions from my project. test_scene.rar 1
sebastianbah Posted May 5, 2016 Posted May 5, 2016 Hi, Thanks for the scene! As for overlaping problem, please, add GUI_ALING_BACKGROUND to your widget's code. So 29 line in unigine_project.cpp should be: engine.gui.addChild(sprite,GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND | GUI_ALIGN_RIGHT); As for the problem with inertia of scheme, we're still investigating it.
sebastianbah Posted May 6, 2016 Posted May 6, 2016 I'm afraid, due to the current realization of the WidgetSpriteViewport, there might be some problems with latency on high camera speed or with low FPS. If such behavior is not suitable, you may try the following solutions: 1. Use widgetCanvas: samples: samples/widgets/canvas_02,03 pros: - potentially low performance drop - no lag cons: - have to manually set the geometry and sort vertexes 2. Use Viewport: pros: - no lag cons: - suitable for c++ only - perfomance drop will be the same as with WidgetSpriteViewport Step by step instruction for Viewport: - create Viewport and get the texture using renderTexture2D() (with viewport mask) or renderNodeTexture2D() - create custom post material (or you may use render_copy_2d material with additional alpha blend settings, but it's not available in editor) - find the texture by name using findTexture("color") - set the texture by setImageTexture - set the post material to camera Also, we've added a feature request to our internal tracker to add an option to allow rendering the geometry over all other geometry (ETA - 2.3 release).
teplov-it Posted February 13, 2017 Posted February 13, 2017 Also, we've added a feature request to our internal tracker to add an option to allow rendering the geometry over all other geometry (ETA - 2.3 release). HI! Has this feature been released? Also I have a question: in overlap_sample with WidgetSpriteViewport you use post_deferred_color material. How is this material named now in 2.4?
silent Posted February 13, 2017 Posted February 13, 2017 HI! Has this feature been released? I'm afraid not - it's still under research phase. in overlap_sample with WidgetSpriteViewport you use post_deferred_color material. How is this material named now in 2.4? Please, check the post_deferred_albedo. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
teplov-it Posted February 17, 2017 Posted February 17, 2017 I'm afraid not - it's still under research phase. Oh, what a pity. And when will this feature be realesed? Please, check the post_deferred_albedo. Thank you. Also I've decided to rewrite code from overlap_sample using c++ API, but when I've compiled project and launched it, I've seen only scheme on black screen (see screenshot). What must I do in order to my c++ project works as unigine script project?
silent Posted February 17, 2017 Posted February 17, 2017 Also I've decided to rewrite code from overlap_sample using c++ API, but when I've compiled project and launched it, I've seen only scheme on black screen (see screenshot). What must I do in order to my c++ project works as unigine script project? Without seeing the whole project or small sample code it's hard to say. Oh, what a pity. And when will this feature be realesed?Can't say right now. In case of any updates we will surely let you know. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
teplov-it Posted February 17, 2017 Posted February 17, 2017 Without seeing the whole project or small sample code it's hard to say.I use unigine script code from scene_advanced (overlap_sample in post 4): int init() { sprite = new WidgetSpriteViewport(engine.getGui(), engine.app.getWidth(), engine.app.getHeight()); engine.gui.addChild(sprite, GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND | GUI_ALIGN_RIGHT); sprite.setColor(vec4(1.0f, 1.0f, 1.0f, 0.5f)); sprite.setBlendFunc(GUI_BLEND_SRC_ALPHA, GUI_BLEND_ONE_MINUS_SRC_ALPHA); return 1; } int update() { Player player = engine.game.getPlayer(); if (player != NULL) { Camera camera = player.getCamera(); camera.setPostMaterials("post_deferred_albedo"); camera.setViewportMask(0x02); sprite.setCamera(camera); } return 1; } and I'm doing so: int AppWorldLogic::init() { // Write here code to be called on world initialization: initialize resources for your world scene during the world start. GuiPtr gui = Gui::get(); sprite = WidgetSpriteViewport::create(gui, App::get()->getWidth(), App::get()->getHeight()); gui->addChild(sprite->getWidget(), Gui::ALIGN_OVERLAP | Gui::ALIGN_BACKGROUND | Gui::ALIGN_RIGHT); sprite->setColor(vec4(1.0f, 1.0f, 1.0f, 0.5f)); sprite->setBlendFunc(Gui::BLEND_SRC_ALPHA, Gui::BLEND_ONE_MINUS_SRC_ALPHA); return 1; } // start of the main loop int AppWorldLogic::update() { // Write here code to be called before updating each render frame: specify all graphics-related functions you want to be called every frame while your application executes. PlayerPtr p = Game::get()->getPlayer(); if (Editor::get()->getPlayer() != (PlayerPtr)NULL) p = Editor::get()->getPlayer(); CameraPtr camera = p->getCamera(); camera->setPostMaterials("post_deferred_albedo"); camera->setViewportMask(0x02); sprite->setCamera(camera); return 1; } After compilation I've seen scheme on black screen (screenshot in previous post) although I expect to see normal background (screenshot in this post)
