[SOLVED] Can't pass vec3 to externed function
Hey, I'm trying to create a function in c++ and export it to UnigineScript.  I'm trying to follow the "dot" example you have in the documentation.  But I can't get it to work after trying lots of things.
The function is defined something like this:
void someFunc(const vec3 &a, vec3 &b, vec3 &cl)
I am exporting it like this:
Interpreter::addExternFunction("someFunc", MakeExternFunction(&someFunc));
Then I call it in script like this:
vec3 a, b, c;
someFunc(a, b, c);
But I get this error message:
camera_control.h:222: Variable::getExternClassObject(): can't convert vec3 to struct Unigine::Math::vec3 * __ptr64
What am I doing wrong?
Conversion from "Variable" to "vec3 &" is not defined.
There are defined conversions for "vec3" and "const vec3 &".
So I suppose signature of your function should be:
void someFunc(const vec3 &a, const vec3 &b, const vec3 &c).
Is there no pass by reference then?  I wanted to be able to pass a couple of vec3s back out.
I'm afraid not.
There is workaround however: you can pass reference to an instance of extern class.
class VectorPair {
    vec3 a;
    vec3 b;
    vec3 getA() const { return a; }
    vec3 getB() const { return b; }
void foo(const Variable &v) {
    VectorPair &ret = v.getExternClassObjectRef<VectorPair>(Interpreter::get());
    ret.a = vec3(1,2,3);
    ret.b = vec3(4,5,6);
ExternClass<VectorPair> *c = MakeExternClass<VectorPair>();
c->addConstructor();
c->addFunction("getA",&VectorPair::getA);
c->addFunction("getB",&VectorPair::getB);
Interpreter::addExternClass("VectorPair",c);
Interpreter::addExternFunction("foo",MakeExternFunction(&foo));
