cinetec_tech Posted March 14, 2016 Share Posted March 14, 2016 hi: We currently want to separate a feature to a plugin and still could access that plugin from c++ level instead of script. so could you provide us a sample to access plugin functions across plugins or app? thanks Link to comment
maxi Posted March 15, 2016 Share Posted March 15, 2016 Hi, You can just include plugin's header and get plugin instance in project's world logic, for example: plugin header file: // some extern class declaration: class MyExternClass { ... }; // plugin declaration class MyPlugin : public Plugin { ... // api MyExternClass *getExternClass(); } project WorldLogic class: class AppWorldLogic : public WorldLogic { public: AppWorldLogic() {} virtual ~AppWorldLogic() {} virtual int init() { // assume, that plugin has been loaded EnginePtr engine; int id = engine->findPlugin("plugin/plugin"); if (id == -1) { Log::message("can't find plugin\n"); return 0; } // get plugin interface Plugin *pl = Engine::get()->getPluginInterface(id); if (!pl) { Log::message("plugin is null\n"); return 0; } // cast to our class MyPlugin *plugin = static_cast<MyPlugin*>(pl); if (!plugin) { Log::message("cant cast\n"); return 0; } // create custom class from plugin MyExternClass *extern_class = new MyExternClass(); extern_class->print("hello from c++"); // use plugin's api MyExternClass *extern_class2 = plugin->getExternClass(); extern_class2->print("hello from c++ 2"); return 1; } }; // starting main loop with system and world logic for example int main(int argc,char **argv) { EnginePtr engine(UNIGINE_VERSION,argc,argv); AppSystemLogic system_logic; AppWorldLogic world_logic; engine->main(&system_logic, &world_logic, NULL); return 0; } Link to comment
cinetec_tech Posted March 16, 2016 Author Share Posted March 16, 2016 thanks Maxi: We also would like to call an app function from a plugin directly. is this possible? example: We have our own app to handle the updates and keyboard events. We want to create a plugin which could call the app function to register a keyboard callback event. so the plugin could handle keyboard events too. thanks alot Link to comment
maxi Posted March 18, 2016 Share Posted March 18, 2016 Please check out samples/Api/Systems/Plugins example. You can inherit any of logics classes (WorldLogic, SystemLogic, EditorLogic) in plugin's project, add this logic to engine by calling Engine::add...Logic and make your own logic there implementing init, update, shutdown. Link to comment
cinetec_tech Posted April 18, 2016 Author Share Posted April 18, 2016 hi Maxi: just come back and continue this question: we have a c++ class MyExternClass in a plugin. it's instanced in unigine script MyexternClass myclass=new MyexternClass() and it's starting to store some data in the instance from script update; Now i need to access this instance from another plugin to get those data. is this possible? thanks Link to comment
cinetec_tech Posted April 18, 2016 Author Share Posted April 18, 2016 also could you explain how // api MyExternClass *getExternClass(); this works without implementation? Link to comment
maxi Posted April 20, 2016 Share Posted April 20, 2016 Hi, also could you explain how this works without implementation? This will work only for c++ when you add plugin's header to your project, implementation is available, when engine loads plugin's dll. hi Maxi: just come back and continue this question: we have a c++ class MyExternClass in a plugin. it's instanced in unigine script MyexternClass myclass=new MyexternClass() and it's starting to store some data in the instance from script update; Now i need to access this instance from another plugin to get those data. is this possible? thanks You can create a class in c++ and move it to the script, that will perform some logic with it, for example: // C++ //function that return variable with extern class: Unigine::Variable getExternClass() { // create object or get it from storage whatever MyexternClass *myclass = new MeexternClass(); Unigine::Variable var; // add your extern class to variable, check out append and manage flags for owning logic var.setExternClassObject(Unigine::Engine::get()->getWorldInterpreter(), "MyexternClass", myclass); return var; } // add function to script, from a global or a member function Unigine::Interpreter::addExternFunction("getExternClass", MakeExternFunction(&getExternClass)); // script MyexternClass myclass = getExternClass(); ... do some logic with it Link to comment
