Simon.Anderson Posted February 23, 2016 Share Posted February 23, 2016 Hi all, Does anyone know of a way to fully clip (or render) complete nodes/meshes in the scene that partially intersect near/far camera clipping planes? For example, objects that partially intersect the far clipping plane for the player object are currently getting cut in half - I'd like to instead show the entire object if any part of it hits the clipping plane. Any help/ideas would be much appreciated. Thanks, Simon Link to comment
ulf.schroeter Posted February 23, 2016 Share Posted February 23, 2016 Usage of object per-surface Object::setMin/MaxVisibleDistance() might do the trick. Setting properly calculated object per-surface min/max distance based on surface bounding radius and configured near/far plane distance could be used to completely hide/show surfaces close to the clipping planes, even though this will not be 100% precise and also cumbersum to configure/tune properly. Link to comment
