[SOLVED] Field Spacer limitations
Using Field Spacers to cull grass objects from our roadway.  The grass comes back when multiples Spacers are used within the scene.  Is there a limitation to their use or am I improperly using them?
Hi Joel,
According to our QA guys current limitations of any spacers objects are:
  • 8 spacers (Field / Animation) simultaneously in the viewport for single object (with the same Field mask).
So, if you have multiple ObjectGrass instances you can hide up to 8 parts simultaneously for each ObjectGrass instance.
We will check if it is possible to increase that limit in the future.
  • 5 weeks later...
  • 4 weeks later...
