liyan Posted January 6, 2016 Share Posted January 6, 2016 I created a new world with 2.1.1,and added Neuron 2.1 form Add-Ons,but it can't load "Neuron_x64.dll". Why? Tahnks Link to comment
xianjun.wu Posted January 7, 2016 Share Posted January 7, 2016 1. please check neuron_x64.dll is already in the bin folder 2. you should install "Axis Neuron" application from Neuron perception first. Open it, connect with your device. Then in setting options, open the BVH options Link to comment
liyan Posted January 8, 2016 Author Share Posted January 8, 2016 1. please check neuron_x64.dll is already in the bin folder 2. you should install "Axis Neuron" application from Neuron perception first. Open it, connect with your device. Then in setting options, open the BVH options Can I speak Chinese with you? Link to comment
liyan Posted January 8, 2016 Author Share Posted January 8, 2016 1. please check neuron_x64.dll is already in the bin folder 2. you should install "Axis Neuron" application from Neuron perception first. Open it, connect with your device. Then in setting options, open the BVH options When I create the new project I have choose the "Perception Neuron 2.1 " from the Add-ons so "neuron_x64.dll" is in the bin folder. And I have been install "Axis Neuron" . I use win10, is that a problem? Link to comment
xianjun.wu Posted January 11, 2016 Share Posted January 11, 2016 you should keep opening Axis Neuron application. Than connect your device. When it is done, open the bvh options 请把Axis Neuron这个软件打开,然后连接设备,再把bvh打开。一定要在axis neuron看到那个人是动的才可以 Then in the run command line write : -extern_plugin "Neuron" 然后在run的下面有个设置,在customer下打入命令-extern_plugin "Neuron" you can check the plugin if it is loaded correctly by press ` 然后按`看信息里neuron这个插件有没有被正确载入 Link to comment
liyan Posted January 12, 2016 Author Share Posted January 12, 2016 图片1 https://developer.unigine.com/en/gtfl/514 图片2 https://developer.unigine.com/en/gtfl/515 图片3 https://developer.unigine.com/en/gtfl/516 图片4 https://developer.unigine.com/en/gtfl/517 就像您说得那样做得,但是还是提示不能加载 Link to comment
xianjun.wu Posted January 12, 2016 Share Posted January 12, 2016 hi, sorry, it require neuron sdk dll, and put it in bin floder. 你好,下载这个dll,把他放到bin下应该就可以了 Link to comment
liyan Posted January 12, 2016 Author Share Posted January 12, 2016 Neuron 应该是加载进来了,但是我怎么才能知道有没有收到“Axis Neuron”分过来的数据呢? Link to comment
liyan Posted January 12, 2016 Author Share Posted January 12, 2016 hi, sorry, it require neuron sdk dll, and put it in bin floder 你好,下载这个dll,把他放到bin下应该就可以了 Neuron 应该是加载进来了,但是我怎么才能知道有没有收到“Axis Neuron”分过来的数据呢? Link to comment
xianjun.wu Posted January 12, 2016 Share Posted January 12, 2016 在neuron add-ons的文件夹里有一个neuron.cpp 文件,里面有些代码可以测试 sdk/addons/neuron_addon_windows_2.1.1/data/samples/plugins/ 这个插件我会完善,以后会出一个demo Link to comment
liyan Posted January 12, 2016 Author Share Posted January 12, 2016 在neuron add-ons的文件夹里有一个neuron.cpp 文件,里面有些代码可以测试 sdk/addons/neuron_addon_windows_2.1.1/data/samples/plugins/ 这个插件我会完善,以后会出一个demo 打开后得到了“Neuron plugin: cannot connect neuron device”,"neuron.cpp"里需要修改的应该只有IP吧,改为我自己的IP。 在Axis Neuron里面使用的是UDP的协议,IP是我自己的IP跟"neuron.cpp"里面一致。在log里面显示“ Failed to connect to '192.168.10.19:7001'.” Link to comment
xianjun.wu Posted January 13, 2016 Share Posted January 13, 2016 这个您参考下neuron官方的sdk文档 Link to comment
liyan Posted January 13, 2016 Author Share Posted January 13, 2016 这个您参考下neuron官方的sdk文档 ok,谢谢啦~neuron的demo什么时候可以更新呢 Link to comment
