honya Posted November 29, 2015 Share Posted November 29, 2015 Hi, i have several skinner blocks that set switch speed on switch block. For don't rewrite switch speed when two or more blocks are used, i set this switch speed to each block too. The logic for change switch speed is inside each block. The problem is when i have already around 9 blocks that i must set switch speed between all, then there are too much connection lines between blocks. The question is: it exist better solution for this situation, for example set one global variable for this blocks, or set that variable is reference? Thanks Honya Link to comment
