[SOLVED] Cannot seem to get access to an ObjectMeshSkinned node instance.
Code:
void Vehicle::setMeshSkinned( const Variable& v )
ObjectMeshSkinnedPtr m = VariableToType<ObjectMeshSkinnedPtr>( Interpreter::get(), v ).value;
I get compile-time errors:
… unigine\sim_windows_2.0_src\include\UnigineInterpreter.h(1450): error C2440: 'type cast' : cannot convert from 'void *' to 'Unigine::ObjectMeshSkinnedPtr'
1> No constructor could take the source type, or constructor overload resolution was ambiguous
… unigine\sim_windows_2.0_src\include\UnigineInterpreter.h(1450) : while compiling class template member function 'Unigine::VariableToType<Unigine::ObjectMeshSkinnedPtr>::VariableToType(void *,const Unigine::Variable &)'
… Vehicle.cpp(90) : see reference to function template instantiation 'Unigine::VariableToType<Unigine::ObjectMeshSkinnedPtr>::VariableToType(void *,const Unigine::Variable &)' being compiled
… Vehicle.cpp(90) : see reference to class template instantiation 'Unigine::VariableToType<Unigine::ObjectMeshSkinnedPtr>' being compiled
If instead I try:
void Vehicle::setMeshSkinned( ObjectMeshSkinnedPtr mesh )
Then it fails to compile this when registering the method:
my_vehicleClass->addFunction( "setMeshSkinned", &SoapProxyVehicle::setMeshSkinned );
I have also tried passing in a NodePtr instead, and trying to cast it to an ObjectMeshSkinnnedPtr but I can't see a legal method for doing that.
Is there a better way to get access to the ObjectMeshSkinned?
Hi Ed,
Use the following code:
void ClassName::setMeshSkinned(Variable &o)
	ObjectMeshSkinnedPtr m = ObjectMeshSkinned::create(o.getObject(Unigine::Engine::get()->getEditorInterpreter()));
