yigitakkok Posted October 8, 2015 Share Posted October 8, 2015 Hi, I have particles and I want them to affected from physical wind. My car is affected from wind ( can't reach maximum speed) but particles are not affected. Here is my code: pos_araba = target_car.getPosition(); vec3 direc = target_car.getDirection(); vec3 windvolumepos = pos_araba + rotateZ(180.0 * atan2(direc.y, direc.x) / PI) * vec3(5.0, -5.0, 1.0); //MUZAFFER: rüzgar wind = add_editor(new PhysicalWind(vec3(10,20,10))); wind.setLinearDamping(0.16f); wind.setAngularDamping(0.16f); wind.setVelocity(vec3(0.0f,0.0f,5.0f)); wind.setWorldTransform(translate(windvolumepos)); volume = add_editor(new ObjectVolumeBox(vec3(10,20,10))); volume.setMaterial("volume_fog_base","*"); volume.setMaterialParameter("diffuse_color",vec4(1.0f,0.0f,0.0f,0.0f),0); volume.setWorldTransform(translate(windvolumepos)); To check out where is the wind box is I created a volume box. Here is my code for particles: particlesbaca = add_editor(new ObjectParticles()); particlesbaca.setMaterial("particles_base","*"); //particlesbaca.setMaterialParameter("diffuse_color",vec4(1.0f,0.0f,0.0f,0.0f),0); particlesbaca.setMaterialParameter("diffuse_color",vec4(0.3f,0.3f,0.3f,0.0f),0); particlesbaca.setWorldTransform(translate(Vec3(0.0f,2.0f,1.5f))); particlesbaca.setParticlesType(OBJECT_PARTICLES_TYPE_LENGTH); particlesbaca.setSpawnRate(300.0f); //saniyede kaç tane üretilecek particlesbaca.setLengthStretch(0.01f); //uzatma particlesbaca.setLinearDamping(0.0f); particlesbaca.setEmitterType(OBJECT_PARTICLES_EMITTER_POINT); particlesbaca.setEmitterDirection(vec3(0.1f,0.0f,0.1f));//target_car.getBackPosition()); //yönü particlesbaca.setEmitterSpread(vec3(0.0f,0.0f,0.0f)); //particialların alanı particlesbaca.setEmitterSize(vec3(0.0f,0.0f,0.0f)); //boyut particlesbaca.setEmitterEnabled(1); particlesbaca.setGravity(vec3(0.0f,0.0f,-9.8f)); particlesbaca.setLife(2.0f,0.0f); particlesbaca.setRadius(0.1f,0.5f); particlesbaca.setVelocity(10.0f,0.0f); particlesbaca.setCulling(1); particlesbaca.setCollision(0); particlesbaca.setIntersection(0); particlesbaca.setEnabled(1); particlesbaca.setParent(target_car.getObject()); Should I turn or off an attribute for particles? Link to comment
ulf.schroeter Posted October 9, 2015 Share Posted October 9, 2015 As far as I know particles do not take part in physics simulation. You can use ObjectParticles.addForce() to simulate wind influence. Link to comment
yigitakkok Posted October 9, 2015 Author Share Posted October 9, 2015 But in here (https://developer.unigine.com/en/docs/1.0/objects/effects/particles/#physical) it says: Besides being thoroughly physical from the point of view of internal simulation (simulation parameters are dwelt below), the particles can also accurately interact with the environment through physical nodes: wind, force and water. So I think particles should be affected. Link to comment
ulf.schroeter Posted October 9, 2015 Share Posted October 9, 2015 yep, you're right. In this case maybe you have to specify particle mass via ObjectParticles.setPhysicalMass() ? Maybe it's initialized by default to a value of 0.0, effectively disabling physical interaction. Link to comment
yigitakkok Posted October 9, 2015 Author Share Posted October 9, 2015 I have set physical mask to 100.0f but still no change... :unsure: Link to comment
ulf.schroeter Posted October 9, 2015 Share Posted October 9, 2015 setPhysicalMASK() takes into argument and should be set to same bit mask value (e.g. 1) as the Wind object, so the particles get affected by the wind object. In addition also use setPhysicalMASS() for assigning particle weight. I would use a smaller mass value e.g. 0.1 or 1.0 for testing. Link to comment
yigitakkok Posted October 9, 2015 Author Share Posted October 9, 2015 Actually I did set mass to 100.0f. Sorry for mistake. Now I have set values according to your answer: particlesbaca.setPhysicalMask(wind.getPhysicalMask()); particlesbaca.setPhysicalMass(1.0f); But still no effect. Link to comment
ulf.schroeter Posted October 9, 2015 Share Posted October 9, 2015 Have you also previously set non-0 physical mask value for wind object (e.g. PhysicalWind.setPhysicalMask(1) ) ? Link to comment
yigitakkok Posted October 12, 2015 Author Share Posted October 12, 2015 I did not but I checked the value of wind.getPhysicalMask and it is 1 already. Link to comment
ulf.schroeter Posted October 12, 2015 Share Posted October 12, 2015 Ok, that I have no more ideas left, sorry. I think it would be helpful if you could provide a minimalistic test scene illustrating the problem for evaluation by Unigine crew Link to comment
maxi Posted October 13, 2015 Share Posted October 13, 2015 Hi Yiğit, I've just created test scene with wind and particles with your parameters, add physical mass and it works: PhysicalWind wind = addToEditor(new PhysicalWind(vec3(1000.0f))); wind.setVelocity(vec3(-5.0f,0.0f,1.0f)); wind.setLinearDamping(8.0f); wind.setAngularDamping(8.0f); ObjectParticles particles = addToEditor(new ObjectParticles()); particles.setMaterial("particles_base","*"); particles.setMaterialParameter("diffuse_color",vec4(0.3f,0.3f,0.3f,0.0f),0); particles.setWorldTransform(translate(Vec3(0.0f,2.0f,1.5f))); particles.setParticlesType(OBJECT_PARTICLES_TYPE_LENGTH); particles.setSpawnRate(300.0f); //saniyede ka? tane ?retilecek particles.setLengthStretch(0.01f); //uzatma particles.setLinearDamping(0.0f); particles.setEmitterType(OBJECT_PARTICLES_EMITTER_POINT); particles.setEmitterDirection(vec3(0.1f,0.0f,0.1f));//target_car.getBackPosition()); //y?n? particles.setEmitterSpread(vec3(0.0f,0.0f,0.0f)); //particiallar?n alan? particles.setEmitterSize(vec3(0.0f,0.0f,0.0f)); //boyut particles.setEmitterEnabled(1); particles.setGravity(vec3(0.0f,0.0f,-9.8f)); particles.setLife(2.0f,0.0f); particles.setRadius(0.1f,0.5f); particles.setVelocity(10.0f,0.0f); particles.setCulling(1); particles.setCollision(0); particles.setIntersection(0); particles.setEnabled(1); particles.setPhysicalMass(0.057f); Changing wind velocity or enabling/disabling it, changes particles direction. If this wont help, please send us your test scene. 1 Link to comment
yigitakkok Posted November 4, 2015 Author Share Posted November 4, 2015 Hi Yiğit, I've just created test scene with wind and particles with your parameters, add physical mass and it works: PhysicalWind wind = addToEditor(new PhysicalWind(vec3(1000.0f))); wind.setVelocity(vec3(-5.0f,0.0f,1.0f)); wind.setLinearDamping(8.0f); wind.setAngularDamping(8.0f); ObjectParticles particles = addToEditor(new ObjectParticles()); particles.setMaterial("particles_base","*"); particles.setMaterialParameter("diffuse_color",vec4(0.3f,0.3f,0.3f,0.0f),0); particles.setWorldTransform(translate(Vec3(0.0f,2.0f,1.5f))); particles.setParticlesType(OBJECT_PARTICLES_TYPE_LENGTH); particles.setSpawnRate(300.0f); //saniyede ka? tane ?retilecek particles.setLengthStretch(0.01f); //uzatma particles.setLinearDamping(0.0f); particles.setEmitterType(OBJECT_PARTICLES_EMITTER_POINT); particles.setEmitterDirection(vec3(0.1f,0.0f,0.1f));//target_car.getBackPosition()); //y?n? particles.setEmitterSpread(vec3(0.0f,0.0f,0.0f)); //particiallar?n alan? particles.setEmitterSize(vec3(0.0f,0.0f,0.0f)); //boyut particles.setEmitterEnabled(1); particles.setGravity(vec3(0.0f,0.0f,-9.8f)); particles.setLife(2.0f,0.0f); particles.setRadius(0.1f,0.5f); particles.setVelocity(10.0f,0.0f); particles.setCulling(1); particles.setCollision(0); particles.setIntersection(0); particles.setEnabled(1); particles.setPhysicalMass(0.057f); Changing wind velocity or enabling/disabling it, changes particles direction. If this wont help, please send us your test scene. It works. Thanks. Link to comment
