ExBemined Posted October 7, 2015 Share Posted October 7, 2015 This one caused some really nasty bug in our code: class A {}; class B {}; class C { A a; C() { a = new A(); } }; class D : C { B b; D() { b = new B(); } A getA1() { return a; } A getA2() { assert( a is A ); return a; } }; Here getA1() actually returns D::b, while getA2() does return C::a. To make things worse, if you run this with NDEBUG, getA2() changes it behaviour and also returns D::b. So it seems that if you don't explicitly touch a member of your base class, a random variable from the derived class is returned instead. This one in particular is nasty as that it doesn't cause a compile error and neither happens in debugging, since the assertion prevents the bug from happening. Link to comment
futurist Posted October 14, 2015 Share Posted October 14, 2015 Hello, you are absolutely right. I've added this bug to our internal bug trackerFor now you can use this workaround: class A {}; class B {}; class C { A a; C() { a = new A(); } }; class D : C { B b; D() { b = new B(); } A getA1() { return C(this).a; } }; Link to comment
