Sign in to follow this
Wrong output from ObjectMeshSkinned.addMeshSurface(*) function
Hi Jirka,
How do you handle merged mesh UV chaos? Just checked merged mesh in old Engine version: YuBlKaB.png
Share this post
Link to post
Lets say, you merge 4 surfaces, each with UV mapping in [0;1], you also merge textures into atlas - this is goal (for simplification lets assume they have same resolution) and then you change UV coordinates to fit on the atlas for each surface [0;0,5], [0,5;1] etc...Limitation is, that you cant atlas meshes, which are outside [0;1] (or only in one axis by duplication texture there), but this is not an issue, all our character texture are not tiled. Is this explanation sufficent? Or are you interested more into technical implemenation?
Share this post
Link to post
That's OK :)
We are now investigating how we can recreate such functionality in the new engine version (alongside with blend shapes).
Share this post
Link to post
After merge all surfaces to one, i change texture mapping for each vertex to new position.
So i use yours class for make texture atlas, then get new position of each textures and use it for compute new texture position of each vertex.
Share this post
Link to post
That's OK :)
Even if surface merge destroys blend shape support for such mesh, it would be no problem at all. At least in our use case.
Share this post
Link to post
Any progress?
Share this post
Link to post
Hi Jirka,
We started to implement a fix for that use-case couple of weeks ago, but faced a lot of interntal issues that slowing down the implementation. We already changed some API and refactored a lot of animations code, but there are still crashes and instability.
Hope we can finish that task, right now it's on pause. Hope that we can finish it in 2.5 or 2.6...
Share this post
Link to post
In the upcoming update there will be possible to merge surfaces (modified sample code):
 ObjectMeshSkinned torso = node_remove(new ObjectMeshSkinned("wanderer_torso_UMA_male.mesh"));
 engine.editor.addNode(torso);
 torso.setPosition(vec3(1.5f, 0.0f, 0.0f));
 torso.setMaterial("mesh_base", 0);
 ObjectMeshSkinned legs = node_remove(new ObjectMeshSkinned("wanderer_legs_UMA_male.mesh"));
 engine.editor.addNode(legs);
 legs.setPosition(vec3(1.5f, 0.0f, 0.0f));
 legs.setMaterial("mesh_base", 0);
 ObjectMeshSkinned helmet = node_remove(new ObjectMeshSkinned("wanderer_helmet_UMA_male.mesh"));
 engine.editor.addNode(helmet);
 helmet.setPosition(vec3(1.5f, 0.0f, 0.0f));
 helmet.setMaterial("mesh_base", 0);
 ObjectMeshSkinned body = node_remove(new ObjectMeshSkinned("UMA_male.mesh", 1));
 engine.editor.addNode(body);
 body.addMeshSurface("LOD1", torso, 1);
 int surfaceId = body.findSurface("LOD1");
 body.addMeshSurface(surfaceId, legs, 1);
 body.addMeshSurface(surfaceId, helmet, 1);
 body.setFrame(0,0);
 body.setMaterial("mesh_base", surfaceId);
Share this post
Link to post
wow, great news, thanks!
Share this post
Link to post
