Issue in .prop file after saving properties
I've created a file library_test.prop that I load in a test project in the init() function :
engine.properties.addWorldLibrary("properties/library_test.prop");
Here is the file (library_test.prop) :
<properties version="1.00">
	<property name="property_aaa">
		<state name="type" type="switch" items="type1,type2">0</state>
		<state name="state1">0</state>
		<parameter name="param1" type="int" max="1000">233</parameter>
		<parameter name="param2" type="float" max="100">30</parameter>
		<parameter name="param3" type="string"/>
	</property>
</properties>
In the editor, in the property panel, I change for example a parameter value and I save the properties (with the floppy icon) :
After that, i quit Unigine (without saving the world), when I reload my script, the property file has changed and I cannot get the parameters anymore in the editor because it seems like the previous save has changes the types of the parameters with "0" like that :
		<parameter name="param1" type="0" max="1000">544</parameter>
		<parameter name="param2" type="0" max="100">30</parameter>
		<parameter name="param3" type="0"/>
	</property>
</properties>
Is there a bug or have I made something wrong ?
Thanks in advance,
Philippe VAZ
Hi Philippe,
It is a bug. I've added it to our internal bug tracker.
Simple workaround is to change state name to something different from "type". For example:
<state name="type_of_object" type="switch" items="type1,type2">0</state>
