renato.semadeni Posted August 10, 2015 Share Posted August 10, 2015 Hi there, we need for our simulation, airport lights which can be seen from different distances. To achieve this, we thought of increasing the size of the lights, implemented as ObjectVolumeSphere, as well as increasing the spacing between the lights in relation to the distance of the eyepoint. Has anybody achieved a correct light system in a different approach? I'm thinking about the light properties or something like this... Thanks in advance, Renato Link to comment
unclebob Posted August 18, 2015 Share Posted August 18, 2015 Hi there, Renato! Take a look at our Portangeles demo as it contains airport lights. Basically, it's just an ObjectBillboards node as its shader is able to render billboards as a single pixel on far distances. Link to comment
renato.semadeni Posted August 18, 2015 Author Share Posted August 18, 2015 Hi Andrey Thanks for your reply, this is clearly an advantage. But we would still have to change the size of the billboard due to distance, right? Or does the shader opens even more possibilities? I mean for getting a combination of lights seen from far away, even if they are already overlapping each other? Kind regards, Renato Link to comment
sebastianbah Posted September 22, 2015 Share Posted September 22, 2015 Hi, As for billboards, on a far distances Angular size option in billboards_base material also may be helpful. https://developer.unigine.com/en/docs/1.0/content/materials/billboards_base/?words=Angular%20size#highlight#states_options Link to comment
