[SOLVED] Errors rebuilding engine
I have added the unigine_vs2013.vcxproj project to my solution file for a C++ application I'm developing.  When I try to build the engine in VS2013, either in Debug-Double or Release-Double I get a ton of build errors.  Most of them appear to be syntax errors.  We are using the most recent release candidate, "UNIGINE_VERSION 0x1000400d."
Attached is a log of the build errors.  Any idea what's wrong?
Thank you for your time,
Andrew
debug-double-build-errors.txt
Hi Andrew,
I'm sorry, but I can't reproduce this behavior with the latest 2.0 RC Sim SDK. I just opened sim_src_win_2.0-RC/source/engine/unigine_vs2013.vcxproj in Visual Studio 2013, changed configuration to Debug-Double x64 (x64 / x86)  and successfully build (the same with Release-Double).
Could you please try to build engine from source directory without copying anything? Also, please, make sure that Platform Toolset option is set to Visual Studio 2013 (vs120) and also <SDK>/include folder are copied to the new location.
Pulling the most recent release candidate and building from scratch fixed the issue.  I can build without errors now.
Thank you for your time.
Andrew
