[SOLVED] what is ball rolling Deceleration speed
I tried to modify the test parameters of physic ..  with body and body Rigid class.
fDensity, fFriction , fRestutution  and addforce ... modify result..
Do not go below a minimum.
I want to stop the ball.
I would like to know the value of the parameter.
Hi, Yongho!
As I understand you want to stop the moving body right? You can use:
- Body::setPosition(Body::getPosition()) - manually setting body position resets it's linear and angular velocities
- Body::setEnabled(0), Body::setEnabled(1) - disabling/enabling resets velocities as well
