danni.coy Posted February 17, 2011 Share Posted February 17, 2011 pgm from the netpbm suite is the only 16bit greyscale image format that Global Mapper supports (a tool we use for getting real terrain into our worlds). This would be a very easy format to write a loader for we would appreciate it very much if Unigine had this capability. Link to comment
steve.brodie Posted February 18, 2011 Share Posted February 18, 2011 Yes some 16bit heightmap format such as (geotiff, pgm or terragen .ter) out of a common GIS package like GlobalMapper would be good. Also I am trying to make a tile with a 16385x16385 heightmap. It appears that i would then need to create 64x64 detail diffuse maps = 4096 individual maps named correctly (1 for each surface). Am I missing something or is this an absurb proposition. If this is going to be the only way to make a terrain so large maybe Unigine could import a 16385x16385 diffuse detail map and automatically cut it up into the 4096 diffuse tiles (513x513). Otherwise I think the terrain system is going to be pretty pointless for us, unless ive missed something. Link to comment
ulf.schroeter Posted February 21, 2011 Share Posted February 21, 2011 Also I am trying to make a tile with a 16385x16385 heightmap. It appears that i would then need to create 64x64 detail diffuse maps = 4096 individual maps named correctly (1 for each surface). Am I missing something or is this an absurb proposition. I don't think that this has to be done by hand. Have a look into script code import_diffuse_clicked() in data/core/editor/editor_objects_terrain.h. If you want a per-surface resolution of 512x512 diffuse texture pixels, than create a terrain with 32x32 surface size. On import of your 16k diffuse map specify a coarse texture size much smaller (e.g. 2048/4096) than import diffuse texture. This should trigger automatic diffuse input image splitting into 32x32 surfaces without any manual work. Link to comment
ulf.schroeter Posted February 21, 2011 Share Posted February 21, 2011 pgm from the netpbm suite is the only 16bit greyscale image format that Global Mapper supports (a tool we use for getting real terrain into our worlds). This would be a very easy format to write a loader for we would appreciate it very much if Unigine had this capability. Following code adds generic PGM 8-/16-bit grayscale raw format load support to image class. @UNIGINE Some copy and paste and *.PGM file mask in image file dialogs should be sufficent for inclusion in upcomming SDK release. framework/Image.h class Image { .... private: .... int load_pgm(const char *name); .... } framework/Image.cpp int Image::load(const char *name) { .... if(strstr(name,".pgm") || strstr(name,".PGM")) return load_pgm(name); Log::error("Image::load(): unknown format of \"%s\" file\n",name); return 0; } /******************************************************************************\ * * PGM 8-/16-bit grayscale raw format * \******************************************************************************/ /* */ int Image::load_pgm(const char *name) { File file; if(file.open(name,"rb") == 0) { Log::error("Image::load_pgm(): can't open \"%s\" file\n",name); return 0; } // read PGM header char buffer[256]; // check raw PGM P5 magic file.readLine( buffer, 256); if( ( buffer[0] != 'p' && buffer[0] != 'P' ) || buffer[1] != '5' ) { Log::error("Image::load_pgm(): invalid PGM type, only P5 raw PGM supported"); file.close(); return 0; } // get image size file.readLine( buffer, 256 ); while( buffer[0] == '#' ) { // skip comment lines file.readLine( buffer, 256 ); } int width = 0; int height = 0; sscanf(buffer, "%d %d", &width, &height ); if( width <= 0 || height <= 0 ) { Log::error("Image::load_pgm(): invalid size %d x %d", width, height); file.close(); return 0; } size_t size = width * height; // get max grayscale file.readLine( buffer, 256 ); while( buffer[0] == '#' ) { // skip comment lines file.readLine( buffer, 256 ); } int grayscale_max = 0; sscanf(buffer, "%d", &grayscale_max ); if( grayscale_max < 256 ) { // 8 bit grayscale create2D(width,height,FORMAT_R8,1,0); file.readUCharArray(data,(int)size); } else if( grayscale_max < 65536 ) { // 16 bit grayscale create2D(width,height,FORMAT_R16,1,0); file.readUShortArrayBig((unsigned short*)data,(int)size); } else { Log::error("Image::load_pgm(): invalid grayscale max value %d", grayscale_max); file.close(); return 0; } file.close(); return 1; } tools/ImageView/main.cpp ImageViewer::ImageViewer(int argc,char **argv) { ..... // load directory Dir dir; if(dir.open("./")) { for(int i = 0; i < dir.getNumFiles(); i++) { const char *name = dir.getFileName(i); if(strstr(name,".tga") || strstr(name,".TGA") || .... strstr(name,".pgm") || strstr(name,".PGM")) { images.append(String(name)); } } dir.close(); } .... pgm-test-samples.zip Link to comment
frustum Posted February 22, 2011 Share Posted February 22, 2011 Ulf, thanks. Support of PPM/PGM 8/16bit binary formats is ready. Link to comment
danni.coy Posted February 22, 2011 Author Share Posted February 22, 2011 Ulf - you rock... Link to comment
steve.brodie Posted March 22, 2011 Share Posted March 22, 2011 I have not been able to find an option for import of the PGM format in the terrain object import dialog? How do i get this option to appear. Link to comment
frustum Posted March 22, 2011 Share Posted March 22, 2011 I forgot to add new extension into the editor. You should edit data/core/editor/editor_dialogs.h file on 2936 line, and add ".ppm.pgm" string to extensions. Link to comment
steve.brodie Posted March 29, 2011 Share Posted March 29, 2011 I have applied the add ".ppm.pgm" string to extensions. however it crashes on import of the greyscale pgm file. I have attached one if you could have a look at it. Also, it seems that Unigine always mirrors the maps vertically onto the terrain. Can we get this changed or have an option to align it right way up. Thanks Link to comment
frustum Posted March 29, 2011 Share Posted March 29, 2011 Give me an example of problem .pgm file please. I will fix importing code before update. Link to comment
ulf.schroeter Posted March 29, 2011 Share Posted March 29, 2011 Also, it seems that Unigine always mirrors the maps vertically onto the terrain. Can we get this changed or have an option to align it right way up. Vertically or horizontally ? Horizontal flip might be 'caused' by default-texture-orientation Link to comment
frustum Posted March 29, 2011 Share Posted March 29, 2011 I have added horizontal flip option for heights/holes import/export. Link to comment
steve.brodie Posted April 4, 2011 Share Posted April 4, 2011 I have added horizontal flip option for heights/holes import/export. i am uploading an example pgm here Link to comment
