kevin Posted June 21, 2015 Share Posted June 21, 2015 I'm currently working from the QtApp example in which the main thread is controlled by Qt, and the Unigine engine lives in the same thread. It seems that it's not possible to make engine calls outside of the main thread (which makes sense), but it's generally good practice to offload expensive tasks to a non-GUI thread. For example, I'm attempting to load a large mesh (>1 million triangles) at runtime. This currently hangs the program for a number of seconds. Ideally, I would create a new thread and load the mesh there, making it such that the GUI doesn't freeze. However, this doesn't work since meshes must be created/loaded in the engine thread (which is also the Qt/GUI thread). What options do I have for achieving this functionality? It seems like the best method would be to initialize the engine in a separate (non-GUI) thread, but I'm not sure how the engine and GUI threads can be synchronized. Thanks, Kevin Link to comment
ulf.schroeter Posted June 21, 2015 Share Posted June 21, 2015 Use UNIGINE script engine.world.loadAsyncNode() and engine.world.getAsyncNode() or C++ interface Unigine::World::loadAsynchNode() and Unigine::World::getAsyncNode() threaded background streaming functions instead of spawning your own threads. Depending on the specific use-case it might also be feasible to use WorldLayer node for distance-based automatic loading/unloading of node files. 1 Link to comment
kevin Posted June 21, 2015 Author Share Posted June 21, 2015 Thanks! This looks promising. Is there a way to generalize this to .mesh files / more specific node types? E.g., can I perform the following calls asynchronously: Unigine::ObjectMeshStaticPtr mesh = Unigine::ObjectMeshStatic::create(0); mesh->loadMesh("file.mesh"); I haven't had any luck finding code examples using asynch calls. Link to comment
ulf.schroeter Posted June 22, 2015 Share Posted June 22, 2015 You have to wrap your mesh as ObjectMeshStatic node in an external XML node file (can be done in the editor by exporting imported mesh node. In general all kinds of Uni gone node types, material libraries can be placed in such node file for async loading) When you want to load this mesh node file kick off the background load via loadAsyncNode() and store returned load operation identifier in some list. On each follow-up frame check end of load via getAsyncNode(id). If return value is <> 0 than you can cast the return value to ObjectMeshStatic and use it as appropriate (This should work if ObjectMeshStati node is the only node in the file, otherwise you have to traverse returned node hierarchy for finding mesh node). Might be necessary to add the node to the editor for automatic memory garbage collection on destruction, otherwise you'll have to handle object deletion on your own (though I am not 100% sure here) Link to comment
binstream Posted June 22, 2015 Share Posted June 22, 2015 Actually we have data steaming as the next target for improvement in Q3 2015, so things might be changed soon. Link to comment
kevin Posted June 22, 2015 Author Share Posted June 22, 2015 Perfect, thanks all for the help. Link to comment
