cinetec_arthur Posted June 16, 2015 Share Posted June 16, 2015 hi, I added a complicated script code to unigine editor. At last, I got a wrong code "editor/editor.cpp:328:NameSpace::NameSpace(): maximum namespace is 65535". What's wrong with my code? And how should I do to solve it? Thanks. Link to comment
cinetec_arthur Posted June 16, 2015 Author Share Posted June 16, 2015 By the way, I ran unigine in debug mode. Link to comment
cinetec_tech Posted June 16, 2015 Share Posted June 16, 2015 we are currently blocked by this issue. we can't write any more functions. it seems already reach the limitation. I check when system loaded, it's already 63500 namespaces used. basically a {} is a namespace. is there anyway to increase the limit? thanks Link to comment
unclebob Posted June 17, 2015 Share Posted June 17, 2015 Hi there, Cinetec! Could you please provide your code with the problem? Link to comment
cinetec_tech Posted June 17, 2015 Share Posted June 17, 2015 hi unclebob: we couln't send all our code. but here is a test you could try. we basically extend the current unigine editor code with our own code so when unigine editor start it will load our ui too. but currently it seems we run out of namespace. simple copy this code to the editor.cpp and reload the editor will reproduce this behavior (it's about 10k lines of code and each line seems consider a namespace in unigine) void test(){ if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1;if (1) int x=1; if (1) int x=1;if (1) int x=1; } Link to comment
unclebob Posted June 17, 2015 Share Posted June 17, 2015 Cinetec, Are you sure you need such complicated code in the editor? ;) Link to comment
unclebob Posted June 17, 2015 Share Posted June 17, 2015 As a workaround, you can try putting your code to editor plugin, because it'll be loaded as a separate expression with its own namespace limit. Link to comment
cinetec_tech Posted June 17, 2015 Share Posted June 17, 2015 hi Bob: We are using the editor plugin in the beginning but later found editor plugin couldn't be cached. so we switched to integrated into editor. is there anyway to increase the namespace or not count a "if" as a new namespace. I guess just the current unigine editor already use 50k namespaces. We have some code depends on unigine editor. so we can't use world script or system script. hope you could give a hand. thanks Link to comment
cinetec_tech Posted June 17, 2015 Share Posted June 17, 2015 Or if there is anyway to split our script into system and editor script? Link to comment
cinetec_tech Posted June 18, 2015 Share Posted June 18, 2015 even not reach the 65535 is still very risky. things like if you load a tracker file with lots of animation, the editor will fail with same error. since unigine is heavily depends on scripting. I hope unigine could be improved to handle more codes. Link to comment
ExBemined Posted June 18, 2015 Share Posted June 18, 2015 I believe that every WorldExpression you have also counts towards this limit, and that if you have multiple WorldExpressions in the scene that use the same script (but are not clones of each other) they count double. We were our way towards the limit as well but in time found out and decided to put more logic in the world script itself rather then in nodes, to avoid code being duplicated. Specially if one of the nodes includes headers like unigine.h it went really fast, because these functions would be compiled numerous times. Still, right now with everything in worldscript and logic in nodes just referencing to the worldscript, we again reached about 89% of the limit... Link to comment
unclebob Posted June 18, 2015 Share Posted June 18, 2015 Hi there, Cinetec!If you have access to our source code, you can easily get rid of this limitation by removing: 11: #define NAMESPACE_MAX_ID 65535 and 113: if(interpreter->namespaces.size() == NAMESPACE_MAX_ID) Interpreter::error("NameSpace::NameSpace(): maximum namespace is %d\n",NAMESPACE_MAX_ID); lines from /source/engine/interpreter/NameSpace.cpp file.We'll consider to do the same and if our tests show us this won't break anything then we'll remove this limitation completely. Link to comment
ExBemined Posted June 18, 2015 Share Posted June 18, 2015 Hi, it seems the main problem are these defines: #define NAMESPACE(ID,NUM) (((NUM) << 16) | (ID)) #define NAMESPACE_ID(ID) (((unsigned int)(ID)) & 0xffff) #define NAMESPACE_NUM(ID) (((unsigned int)(ID)) >> 16) This if for example used to store function ids in the lower 16 bits of an integer. So I guess these macros have to be adjusted as well. This will limit the amount of members (functions, variables, arrays) of a namespace, but I don't think the 65536 limit will be reached here. I just hope all code uses these macros and there is no other place where the namespace is expected in the lower 16 bits. Link to comment
unclebob Posted June 18, 2015 Share Posted June 18, 2015 Hi Michiel, You're right, it's not that easy as I suggested earlier. You also can't just modify these defines, you have to change all usage code as well (replace int by long so you'll be able to store 32 bits for namespace id and 32 bits for namespace number). Link to comment
ExBemined Posted June 18, 2015 Share Posted June 18, 2015 Would it be possible to alter the bitmasks to give ID 20 bits and NUM 12 bits? So by changing 0xffff to 0xfffff and 16 to 20? This would reduce the number of allowed variables, functions, classes and arrays within a single namespace, but I don't think those come even close to the limit, even the Unigine editor (with a lot of global namespace functions) has 607 functions in the biggest of it's 47740 namespaces. Maybe for safety, it could be a preprocessor define that is off by default, to avoid that if someone did make his entire game using global functions it won't crash. Of course, if it can be turned into 32 bit it would be even better of course. Link to comment
unclebob Posted June 18, 2015 Share Posted June 18, 2015 We'll try 18/14 approach so you'll have 256k namespaces and 16k variables per namespace. Link to comment
cinetec_tech Posted June 18, 2015 Share Posted June 18, 2015 thanks Bemined and Bob: Could you send us a fix soon? thanks Link to comment
silent Posted June 19, 2015 Share Posted June 19, 2015 Hi Cinetec, We are deeply sorry, but a quick test after increasing the NameSpace number shows us a lot of engine crashes. So, there is currently no easy method to increase NameSpace number. Please, consider to move some parts of your code to the system script. We will experiment more with this issue and surely will let you know if we will have some positive results. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
cinetec_tech Posted June 23, 2015 Share Posted June 23, 2015 hi Bob and slient: We tried include our code in unigine.h and remove them from editor.cpp. But the namespace still exceeded. is the unigine.h already included in the editor.cpp namespace? thanks Link to comment
cinetec_tech Posted June 24, 2015 Share Posted June 24, 2015 we would like to see a fix asap. since we are blocked. Link to comment
unclebob Posted June 24, 2015 Share Posted June 24, 2015 Good news, 18/14 approach seems to be working! Here's the fix: NameSpace.h file #define BITS_VARIABLES 14 #define BITS_NAMESPACES 18 #define MASK_NAMESPACES ((unsigned int)(1 << BITS_NAMESPACES) - 1) #define NAMESPACE(ID,NUM) (((NUM) << BITS_NAMESPACES) | ((ID) & MASK_NAMESPACES)) #define NAMESPACE_ID(ID) (((unsigned int)(ID)) & MASK_NAMESPACES) #define NAMESPACE_NUM(ID) (((unsigned int)(ID)) >> BITS_NAMESPACES) #define NAMESPACE_GET(MEMBER,ID) (namespaces[NAMESPACE_ID(ID)]->MEMBER[NAMESPACE_NUM(ID)]) #define NAMESPACE_ARRAY(ARRAY,ID) (ARRAY[NAMESPACE_ID(ID)][NAMESPACE_NUM(ID)]) NameSpace.cpp file #define NAMESPACE_MAX_ID ((unsigned int)(1 << BITS_NAMESPACES) - 1) #define NAMESPACE_MAX_NUM ((unsigned int)(1 << BITS_VARIABLES) - 1) Link to comment
unclebob Posted June 24, 2015 Share Posted June 24, 2015 Update:Also, you have to change inner array limits from short to int as well.NameSpace.h file, line 224: Vector<NameSpace*,int> childs; // child namespaces NameSpace.cpp file, line 137: Vector<NameSpace*,int>::Iterator it = parent->childs.find(this); Link to comment
cinetec_tech Posted June 24, 2015 Share Posted June 24, 2015 thanks Bob. We are trying your solution. Link to comment
silent Posted June 25, 2015 Share Posted June 25, 2015 This fix is also included in the Unigine 2.0 RC. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
