Simon.Anderson Posted May 19, 2015 Share Posted May 19, 2015 Hi, I'm trying to highlight the background of my WidgetComboBox (when it gets clicked on) by creating a Widgetsprite and adding it the parent widget using GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND. I then assign the sprite widget callback GUI_CLICKED to my own callback to draw the highlighting when the sprite is clicked. It works fine and highlights ok, the problem is as soon as I assign a callback to the sprite using sprite.setCallback(GUI_CLICKED... then the combobox stops picking up clicks and never updates. The fact that I assign my own GUI_CLICKED callback to the sprite seems to be the culprit but I'm not sure why? Any ideas/suggestions would be welcome. Thanks, Simon Link to comment
silent Posted May 19, 2015 Share Posted May 19, 2015 Hi Simon, Could you please provide a simple test scene? This surely will help to find the root cause much faster. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Simon.Anderson Posted May 19, 2015 Author Share Posted May 19, 2015 Unfortunately there's a lot of code in our code base and it's all quite complex and interconnected. Very time consuming to pull out into a sample scene :( Link to comment
Simon.Anderson Posted May 19, 2015 Author Share Posted May 19, 2015 Ok, so the following code snippet says it best (it works fine): WidgetSprite sprite = new WidgetSprite(gui,"core/editor/gui/color_white.png"); m_hBox.addChild( sprite, GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND ); // // While the following code below is commented out, the checkbox can be checked and receives mouse clicks // //sprite.setCallback(GUI_CLICKED, "OnRowClickedCB", this, m_rowSprites.size(), GUI_CLICKED); // // The following code adds a checkbox over the top of the sprite - it works fine while the previous code is commented out // WidgetCheckBox checkbox = new WidgetCheckBox(engine.getGui(), ""); m_hBox.addChild(checkbox); And the following code doesn't work: WidgetSprite sprite = new WidgetSprite(gui,"core/editor/gui/color_white.png");m_hBox.addChild( sprite, GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND ); //// While the following code below is commented out, the checkbox can be checked and receives mouse clicks//sprite.setCallback(GUI_CLICKED, "OnRowClickedCB", this, m_rowSprites.size(), GUI_CLICKED); //// The following checkbox DOESN'T work - it displays but doesn't receive clicks and never gets checked because the call to "setCallback" above//WidgetCheckBox checkbox = new WidgetCheckBox(engine.getGui(), "");m_hBox.addChild(checkbox); setting the GUI_CLICKED is the reason the clicks don't work. This seems to be the case for all widgets (not just checkboxes). Is there any way around this or is this a bug? Thanks, Simon Link to comment
maxi Posted May 21, 2015 Share Posted May 21, 2015 Hi, Simon! I've created a simple scene containing your code. Could you add extra code there to recreate the issue? ww.cpp ww.world Link to comment
Simon.Anderson Posted May 25, 2015 Author Share Posted May 25, 2015 Hi there, ok - just paste this init() code into your scene file and you'll see what I mean: int init() { Player player = new PlayerSpectator(); player.setDirection(Vec3(0.755f, -1.0f, 0.25f)); engine.game.setPlayer(player); Gui gui = engine.getGui(); WidgetHBox m_hBox = new WidgetHBox(gui, 0, 0); // Empty string should still load with a red background WidgetSprite sprite = new WidgetSprite(gui, "" ); sprite.setWidth(200); sprite.setHeight(200); m_hBox.addChild(sprite, GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND ); // This causes the checkbox to ignore any mouse clicks sprite.setCallback(GUI_CLICKED, "OnRowClickedCB"); WidgetCheckBox checkbox = new WidgetCheckBox(gui, "combobox"); m_hBox.addChild(checkbox); gui.addChild(m_hBox, GUI_ALIGN_CENTER); return 1;} Basically, All I'm after is a way to change the background colour of my base/bottom containers that contain my widgets that sit on top. This is quite urgent for us - it would be great if you could get back to me asap. Cheers! Simon Link to comment
maxi Posted May 25, 2015 Share Posted May 25, 2015 Hi, Simon, yes, its a known issue. You have 2 options: 1) Set checkboxes as GUI_ALIGN_OVERLAP and set their positions manually 2) Don't set callback to sprite, and manually checks for sprite clicked instead: WidgetSprite sprite; /* */ int init() { Player player = new PlayerSpectator(); player.setDirection(Vec3(0.755f, -1.0f, 0.25f)); engine.game.setPlayer(player); Gui gui = engine.getGui(); WidgetHBox m_hBox = new WidgetHBox(gui, 0, 0); sprite = new WidgetSprite(gui, "" ); sprite.setWidth(200); sprite.setHeight(200); m_hBox.addChild(sprite, GUI_ALIGN_OVERLAP | GUI_ALIGN_BACKGROUND); WidgetCheckBox checkbox = new WidgetCheckBox(gui, "combobox"); m_hBox.addChild(checkbox); gui.addChild(m_hBox,GUI_ALIGN_CENTER); return 1; } /* */ int update() { //check for sprite clicked int x = engine.gui.getMouseX(); int y = engine.gui.getMouseY(); if(x > sprite.getScreenPositionX() && x < (sprite.getScreenPositionX() + sprite.getWidth()) && y > sprite.getScreenPositionY() && y < (sprite.getScreenPositionY() + sprite.getHeight())) { if(engine.gui.getMouseButton() == APP_BUTTON_LEFT) { //change color ets } } return 1; } Link to comment
Simon.Anderson Posted May 26, 2015 Author Share Posted May 26, 2015 Ok thanks - is this fixed in unigine 2.0? And are we any closer to a release? Link to comment
silent Posted May 27, 2015 Share Posted May 27, 2015 Hi Simon, Ok thanks - is this fixed in unigine 2.0? This issue is not yet fixed in Unigine 2.0 beta, sorry. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted June 25, 2015 Share Posted June 25, 2015 The bug was fixed. Fix is available with the Unigine 2.0 RC SDK. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
