pathRoute - movement problem
This is me being stupid, not a unigine issue but I cannot for the life of me work out how to move a character along a path. Can someone take a look and see if I have done something sill here?
#include <core/unigine.h>
vec3 offset = vec3(0.0f, 0.0f, 1.0f);
Vec3 start_pos = Vec3(-0.0f, 0.0f,1.0f) + offset;
Vec3 target_pos = Vec3( 20.0f,-20.0f,1.0f) + offset;
Node agent;
int init() {
  PlayerSpectator camera = new PlayerSpectator();
  camera.setPosition(Vec3(2.0f,0.0f,1.5f));
  camera.setDirection(Vec3(-1.0f,0.0f,-0.5f));
  engine.game.setPlayer(camera);
  NavigationSector navigation = add_editor(new NavigationSector(vec3(1024.0f,1024.0f,9.0f)));
  navigation.setWorldTransform(translate(Vec3(0.0f,0.0f,5.0f) + offset));
  ObstacleBox box = add_editor(new ObstacleBox(vec3(10.0f,10.0f, 3.0f)));
  agent = add_editor(node_load("mup4b/meshes/agent.node"));
  engine.console.run("show_visualizer 1");
int shutdown() {
int update() {
  PathRoute path = new PathRoute(2.0f);
  path.create2D(start_pos, target_pos);
  path.renderVisualizer(vec4_one);
  if (path.isReady()) {
    vec3 current_pos = agent.getPosition();
    vec3 direction_to_face = path.getPoint(1) - path.getPoint(0);
    vec3 move = lerp(agent.getPosition(), path.getPoint(1), 2.0f * engine.game.getIFps());
    mat4 mat = setTo(current_pos * move,
                     direction_to_face,
                     vec3(0.0f, 0.0f, 1.0f));
    agent.setWorldTransform(mat * rotateX(-90) * rotateZ(180));
  } else {
    log.message("Path not ready\n");
Node add_editor(Node node) {
  engine.editor.addNode(node);
  return node_remove(node);
void remove_editor(Node node) {
  engine.editor.removeNode(node);
The path appears correctly, and the character is facing in the right direction but it does not move along the path and I am stumped as to why.
Hey Angus,
Try not to create new PathRoute instance every update call. ;)
Ok - I've updated the code so it now runs the below code in a thread, but it does not seem to make any difference. My code that runs in a thread is below.
void do_movement() {
  sleep(5.0f);
  path.create2D(start_pos, target_pos,1);
  while(1) {
      vec3 move = lerp(agent.getPosition(), path.getPoint(1), 16.0f * engine.game.getIFps());
                       direction_to_face,
      wait;
    } else {
      sleep(1.0f);
Hi Bob. I've attached a RAR of the data directory of the project.
Thanks for looking at this. I'm pretty sure it's just me being dumb but for the life of me I can't figure out where.
mup4b.rar
  • 1 month later...
Hi Angus­,
We are deeply sorry for the late reply.
You are forgotten to check if route is reached (PathRoute::isReached), if false - call path.create2D again. And you need to call create2D from time to time to update it. (try every frame for start, then to improve performance reduce the number of calls).
