renato.semadeni Posted April 17, 2015 Posted April 17, 2015 Hi there I'm trying the change the origin and orientation of an object. It worked fine until I decided to include as well the orientation of the node. I started with the following approach: // // Didn't work - it could only take one of the two transformations UNIGINE_MAT4 apMat = nPtr->getWorldTransform(); apMat.setTranslate(UNIGINE_VEC3(ap.getLat(), ap.getLon(), ap.getAlt())); apMat.setRotateZ(ap.getRotZ()); But as result, my node changed only in the applied rotation. With my second approach, it works... Is this a bug or do I missunderstand the theorie? UNIGINE_MAT4 apMat = nPtr->getWorldTransform(); apMat.setRotateZ(ap.getRotZ()); apMat.setColumn3(3, UNIGINE_VEC3(ap.getLat(), ap.getLon(), ap.getAlt())); nPtr->setWorldTransform(apMat); Kind regards, Renato
unclebob Posted April 19, 2015 Posted April 19, 2015 Hi Renato! setRotate, setTranslate functions will reset current matrix data, so you need to do multiply translation matrix by rotation. But you did much better and faster way. :)
