ataylor Posted April 9, 2015 Share Posted April 9, 2015 engine.config.get* and engine.config.set* are very convenient, useful for storing settings related to my particular Unigine-driven application. Unfortunately, all settings I create are stored in same default unigine.cfg file as stock Unigine settings ("data_path", "engine_threaded", etc...) For multiple reasons, I would like to keep my application-specific settings in a separate file. Is there a way to do this? Or must I read/write to another file using XML or Json functionality? Link to comment
unclebob Posted April 10, 2015 Share Posted April 10, 2015 Hi Adam! You can't write to a different place other that engine config by using engine.config.* functionality. The only way is to write your data directly to a file by using File, Xml or Json class. Also, you can have a look at how we implemented that in our editor in editor_config.h file Link to comment
