[SOLVED] Skybox DDS cubemap orientation
I am experimenting with using a cubemap as a sky environment but I am having difficulties. The tools I use export the cubemap in a certain orientation which appears to be different to how Unigine expects the cubemap. I have attached an image showing where the horizonal cross elements of the cubemap go in the DDS file. However Unigine does not appear to conform to this, from what I can see. I think that the "+Y" (top side of cube) in Unigine is read from the "+Z" centre slot.
Is this a bug in Unigine or in my tools? And is there a tool that writes DDS cubemaps in the format that Unigine expects them in?
Hi Angus,
For cubemap generation you can use ImageDDS tool.
You also can try to use -r 1 option to rotate your image clockwise.
Correct texture example you can find here: <SDK>/data/samples/objects/textures/sky_01.dds (used in world samples/objects/sky_02).
