[SOLVED] Coordinate system und projection
Hi there
We're trying to create with the two external tools, Global Mapper and CityEngine, the data for the Unigine's City Plugin. I know this is not the main topic of this forum. But I think for Port Angeles you faced the same problems and used the same tools, and possibly could give us some hints or help.
- Did you also export from Global Mapper GeoTiff for the height map used in CityEngine to align the buildings and streets to their correct height?
- Which coordinate system and projection did you use as export in Global mapper and as import in CityEngine?
- Is there an alternative approach to align the buildings/roads height instead of using the CityEngine? I tried it in Unigine, and I can only change the whole bunch of buildings... post-1459-0-27784400-1422529009_thumb.png
Thanks in advance,
Renato
Hi Renato,
CityEngine allows to use any source to calculate heightmap data, so you can use what is more suitable for you.
If I remember correctly, we used UTM coordinate system.
Any DCC tool or script, that can generate valid meshes (with correct height data) for the City Import plugin.
Thanks Andrey,
Somehow I can't get the coordinate system to be the same. CityEngine complains that the height model and the osm import are too far away from each other. I'm sure I have a difference in the coordinate system, but can't see where...
I will keep searching :unsure:
Thanks anyway,
Renato
