[SOLVED] Issue with find() on a vector
So, I have a custom class MyClass.  In an event handler I create a vector of these objects like :
class EventHandler
  MyClass mVector[0];
  void addMyClass(MyClass aObject)
    mVector.append(aObject).
  int findObject(MyClass aObject)
    int found = 0;
    if(mVector.find(aObject, NULL) != NULL)
      found = 1;
    return found;
Adding objects to the vector works with no problems.  I can check this by giving each object a unique ID and printing those out.  The problem is find().  If the MyObject I'm looking for is at index 0 it then Unigine will not find it.  find() works as expected if the object is at any other index, well, so far as I can tell anyhow.
Hey Joshua!
First of all, find will return an index, not an object. By passing some value as a second argument you're telling the container to return that value if there was no object. If you're not passed second argument then find will return -1 if it doesn't find anything.
Check this article: https://developer.unigine.com/en/docs/1.0/scripting/language/containers/container_functions#container_find_one_arg
Also, NULL is basically 0, that's it. :)
So in your case what you're doing is "please find my object and if there's no such object then return zero otherwise return its index".
Your code could be easily fixed:
int findObject(MyClass aObject) { return mVector.find(aObject) != -1; }
