cinetec_tech Posted December 20, 2014 Share Posted December 20, 2014 hi: We found in the material buffer script. there is a bug // copy parameters forloop(int i = 0; material.getNumParameters()) { int type = material.getParameterType(i); string name = material.getParameterName(i); if(type == MATERIAL_PARAMETER_COLOR) parameters.append(name,material.getParameter(i)); else if(type == MATERIAL_PARAMETER_SLIDER) parameters.append(name,material.getParameterSlider(i)); else if(type == MATERIAL_PARAMETER_EXPRESSION) parameters.append(name,material.getParameterExpression(i)); } basically it missing something like getParameterArray and will cause data lost. thanks Link to comment
azagniy Posted December 22, 2014 Share Posted December 22, 2014 Hi. Material array parameters is used to special logic and not used in the editor or somewhere else. So be sure that no one parameter will be lost. Link to comment
