a.koryakin Posted November 24, 2014 Share Posted November 24, 2014 Hello. I cant understand how local variables works.i'm using Unigine v1code: class Buildingvoid setState() { int k; ... k++; engine.console.print(typeinfo(k) + " \n"); ... }On Initialisation scene several objects of Building are creared and in In Update setState() are call every second.output: 12345...The question is why int k; do not create new local variable and takes old value? Link to comment
unclebob Posted November 24, 2014 Share Posted November 24, 2014 Hi there! That's because you used uninitialised local variable here which is a bad practice in general. One thing you should know about though is that local variables in Unigine aren't local. They're more like local variable with static modifier in C++. In other words, they're global but visible only in that function. It's not a big deal as long as you assign some values to them. Link to comment
a.koryakin Posted November 25, 2014 Author Share Posted November 25, 2014 Thx unclebob.So solution is: i always have to initialize local variables before using it. Link to comment
