larry.ellis Posted November 17, 2014 Share Posted November 17, 2014 Hello everyone, I'm in the very early stages of testing out the engine, and im trying to import an 8192 (8193) heightmap, but i'm getting some very strange glitches that look as if sections of the terrain are being repeated and also many of the terrain vertices are stretched very high and very low. My process is to create > object > terrain Then choose import tab with the following settings: Overall Size: 8193 Max Height: this varies as i'm still trying to get the height correct LOD distance: 100 Flip Y: Yes The file format has been lots of different types, raw, tga, pgm, png, psd, but they all produce the same results. The highest altitude in the map is 1024, but when setting the height to that, its way too low. I can't seem to figure out a good value to match. I'm using the Alpha Engine 2.0 preview r508 in DX11. Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Hi Larry, Could you please send us your heights texture? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
larry.ellis Posted November 17, 2014 Author Share Posted November 17, 2014 Hi, thanks for the very speedy reply! What format? I'm using all kinds of formats and they are a bit large to send (220mb). I've tried files exported from both World Machine and CryEngine and i get the same results. It doesn't matter what format, the glitch still happens. Should i try the older version of the engine? Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Hi Larry, If results are the same for all formats, could you please send us png image? Also, what image format are you using? R32F should be just fine for the heightmap. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
larry.ellis Posted November 17, 2014 Author Share Posted November 17, 2014 Silly question, but how do i send you the file? Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Sorry, my bad. You can use any file hosting (for example, dropbox), or upload file directly to our FTP server: ftp://files.unigine.com login: upload password: uSh3aihu0ja5 Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
larry.ellis Posted November 17, 2014 Author Share Posted November 17, 2014 I've made a tiny step of progress, the stretched vertices glitch is gone, I simply saved and then re-opened. But now the terrain has some splits in it, dividing the middle up into four chunks. The four chunks are made up of two different sections of the heightmap, both are repeated and mirrored, and are also different heights. This was using PGM format. I can't share the heightmap publicly, can i upload to dropbox and PM you the link? Another silly question, how do you PM on this forum? Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Hi, Please, move mouse cursor to my nickname and wait for a sec for pop-up menu. After that you can click on Send Message button. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
larry.ellis Posted November 17, 2014 Author Share Posted November 17, 2014 Thanks. Pm'd the link. Bed time for me, i'll check back in the morning. Cheers. Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Hi, Sorry, but it seems that we can't reproduce this issue. I've used following settings: 8193x8193; Height: 1200 / 5000 / 10000; LOD: 100; Flip Y: yes; And I get following results: No artifcats at all. Could you please try to create new terrain from scratch in empty world and check again? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
larry.ellis Posted November 18, 2014 Author Share Posted November 18, 2014 Okay, I deleted my old project directory and started fresh. Created a new terrain object and imported the PGM and it looks perfect. I have no idea what the cause was, but its fixed so i can move on. Thanks heaps for your help Silent! Link to comment
