werner.poetzelberger Posted November 11, 2014 Share Posted November 11, 2014 Hi, with that built it very often seems to happen, that textures (4096x4096) are not loaded at project start and reloaded after the source is changed or the object is out of the frustum and comes back to the object. I cannot force it to load by looking/non looking at it, I cant force loading it by loading a different texture into the material slot and then choose the correct one. I have changes the command line parameters to: render_manager_create_textures = 1 and render_manager_textures_memory = 90 It seems that this had an effect one time at loading the project, but now those none loading texture do happen again. It is not always the same texture. I am loading 8.8.8.8 dds textures into standard material DT slot. Is this some known issue or do you think this can be a specific issue with my project/hardware? Unfortunately this issue is not very consistent. It sometimes happens, sometimes not. Best. Werner Link to comment
silent Posted November 12, 2014 Share Posted November 12, 2014 Hi Werner, Is it possible to check the actual test project where texures loading is not working? We've fixed several issues regarding textures loading/compression recently, but I can't say if these fixes will affect on your world, sorry. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
werner.poetzelberger Posted November 12, 2014 Author Share Posted November 12, 2014 I could prepare a scene, sure. Or should I wait for the next SDK first? Thx. Werner Link to comment
silent Posted November 12, 2014 Share Posted November 12, 2014 We can check if this issue is still actual before SDK update. If so, we could try to fix before SDK update release. Otherwise it would take more time to deliver fixed version. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
werner.poetzelberger Posted November 12, 2014 Author Share Posted November 12, 2014 I have uploaded a Scene to the ftp. Cheers. werner Link to comment
