Passing Vectors back to UnigineScript
Are there any examples of how to return a Unigine::vector<Type> back to UnigineScript? It doesn't appear to work in the way that I would expect.
---MyClass.cpp
Unigine::Vector<CustomStruct> &getStruct()
return my_struct;
---Plugin.cpp
ExternClass<MyClass> *my_class= MakeExternClass<MyClass>();
my_class->addConstructor();
my_class->addFunction("getStruct",&MyClass::getStruct);
Interpreter::addExternClass("MyClass",my_class);
MyClass my_class = new MyClass();
CustomStruct structs[] = my_class.getStruct();
Error: Interpreter::parse_expression_array(): "my_class" is not a user array
Hi Philip,
Any data type may be returned,except for vector, map ,and enum.
Also, please check the usage of my_array_vector_generate() in this example: https://developer.unigine.com/en/docs/1.0/cpp_api/usage/arrays?words=my_array_vector_generate,my_array_vector_gener#highlight
So I assume this also applies with structs?
I guess I'll just try to explain what I'm trying to do. So I'm calling an SQLite database in C++ and I'm trying to return the data to UnigineScript, but I'm trying to think of the most practical way to do so.
I'd prefer to perform operations on the data at the UnigineScript level rather than C++.
Simple way for taking all elements
On С++ side you have CustomStruct array.
Two methods fot it:
getNumCustomStructItems()     // returns number of elements in array
getCustomStructItem(int id)     // returns the specific element
Take elements
CustomStruct structs[0] = ();
forloop(int i = 0; my_class.getNumCustomStructItems()) {
  structs.append(my_class.getCustomStructItem(i));
Also, as stated above, please check the usage of my_array_vector_generate() in this example: https://developer.un...gener#highlight
