Object rotation in Y axis bug?
Hi!
I saw something annoying while rotating in Y axis, when angle is grater then 90* the object jumps from side to side and changes its rotation parameters in other axes.
Here is an example when I increased y axis rotation by 1:
Looks like gimbal lock problem. Try to set different rotation order in Tools/Interface window.
I checked it, but I think it wont resolve the problem, because other axis will be have gimbal lock.
don't use interface to do this, try to use script, worldexpresstion, I think you are trying to make a animation, then use quaternion.
If you are not trying to make animation, then the gimbal lock will not be a serious problem.
