ivan.cuevas Posted July 28, 2014 Share Posted July 28, 2014 Hi, In the attached sample it's defined simple A class with two attributes (p_name and p_s1). A clone method is declared to create a new A instance based on current A instance information. The problem is the copy of p_s1 it's not created for the cloned instance. If you change the code to assign the value in a variable, and the cloned instance references this variable the code works ok. clone_00.cpp #include <samples/systems/common/systems.h> ////////////////////////////////////////////////////////////////////////// class A { private: string p_name; string p_s1; public: A(string name, string s1= "") { p_name= name; p_s1= s1; } A clone() { A a= new A(p_name); //string s= this.p_s1; a.p_s1= this.p_s1; log.message("[%s] p_name:'%s' p_s1='%s'", __FUNC__, p_name, p_s1); return a; } string getS1() { return p_s1; } }; ////////////////////////////////////////////////////////////////////////// A global_a; A global_cloned_a; /* */ void update_scene() { while(1) { engine.message("a:'%s' cloned_a:'%s'", global_a.getS1(), global_cloned_a.getS1()); wait; } } /* */ void create_scene() { global_a= new A("global a", "this is S1"); global_cloned_a= global_a.clone(); return "Copy string problem on clone."; } Regards, Iván. clone_00.tar Link to comment
azagniy Posted July 29, 2014 Share Posted July 29, 2014 Hi ivan. In unigine script all variables are static and all private variables are available from all class methods. You are trying to assign value to "p_s1" private variable in clone() method. But this operation "a.p_s1 = this.p_s1" equals "this.p_s1 = this.p_s1". You need to create a setter function for a "p_s1" private variable or send value to clone instance through constructor. Link to comment
ivan.cuevas Posted July 29, 2014 Author Share Posted July 29, 2014 Thanks for the answer, You must recognize it's a quite confusing situation. Is this language feature documented someplace? Link to comment
azagniy Posted July 29, 2014 Share Posted July 29, 2014 All the variables in UnigineScript are static by default. :) see more at UnigineScript tips and tricks Link to comment
ivan.cuevas Posted July 29, 2014 Author Share Posted July 29, 2014 All the variables in UnigineScript are static by default. :) see more at UnigineScript tips and tricks Perfect :D Link to comment
