cem.orsel Posted July 23, 2014 Share Posted July 23, 2014 Hi, I have created a C++ API project, and I am trying to get the editor to work once the project is executed. When I type editor_load in the command line, ı get the following error message: int getResult() { return dialog.getResult(); } core/system/widgets/widget_dialog.h:92: Interpreter::parse_extern_class_begin(): unknown "widgetDialog" class membr "getResult" Editor::editor_load(): can't load "core/editor/editor.cpp" editor script What may be the cause of this error? Link to comment
azagniy Posted July 24, 2014 Share Posted July 24, 2014 Hi. Perhaps this problem stems from the fact that you have the two different versions of the SDK. Make sure that you install only one SDK and this SDK is last version. Make sure that your project linking to unigine lib from right place and last version. It may be from different editor core and engine lib versions. Try to remove all SDK and install last SDK. Link to comment
cem.orsel Posted July 24, 2014 Author Share Posted July 24, 2014 That solved it, thanks :) Link to comment
