danni.coy Posted August 24, 2010 Share Posted August 24, 2010 There are several instances where it would be good to be able to reselect the already selected item in a combo box and have it generate an event. I think that possibly it should not generate a changed event but it should generate a clicked event. Link to comment
Guest extaliones Posted August 24, 2010 Share Posted August 24, 2010 Hello, Widget class is supported a lot of callback types not only GUI_CHANGED (GUI_ENTER,GUI_LEAVE,GUI_CLICKED,GUI_DOUBLE_CLICKED,and etc.), for more information, please, see the following documentation: Programming/Unigine Library/GUI-Related Classes/Gui Class. Link to comment
danni.coy Posted September 3, 2010 Author Share Posted September 3, 2010 Hello, Widget class is supported a lot of callback types not only GUI_CHANGED (GUI_ENTER,GUI_LEAVE,GUI_CLICKED,GUI_DOUBLE_CLICKED,and etc.), for more information, please, see the following documentation: Programming/Unigine Library/GUI-Related Classes/Gui Class. Yes the problem I am having though is that combobox doesn't produce GUI_CLICKED event when the already selected item is clicked, same for GUI_PRESSED. GUI_DOUBLE_CLICKED generates an event but that does not produce the desired user integration. My contention is that GUI_CHANGED should not be generated but GUI_CLICKED should be generated in this case. Link to comment
Guest extaliones Posted September 3, 2010 Share Posted September 3, 2010 Hello, If you select combobox item using setCurrentItem method widget will produce only GUI_CHANGED event, if you clicked widget will produce both GUI_CHANGED and GUI_CLICKED. 1 Link to comment
danni.coy Posted September 3, 2010 Author Share Posted September 3, 2010 Hello, If you select combobox item using setCurrentItem method widget will produce only GUI_CHANGED event, if you clicked widget will produce both GUI_CHANGED and GUI_CLICKED. But not if I select the option with the mouse that is already selected. Well this is partly true. I suspect that the click option is checking for the mouse being inside the area that the combo box takes up when not clicked before sending a clicked signal - It should do this for the area of the UI that is visible when the drop down list is visible. Link to comment
Guest extaliones Posted September 6, 2010 Share Posted September 6, 2010 Hello, WidgetComboBox produces GUI_CHANGED and GUI_CLICKED events simultaneously. We will add GUI_CLICKED event as separate. Link to comment
danni.coy Posted September 6, 2010 Author Share Posted September 6, 2010 Hello, WidgetComboBox produces GUI_CHANGED and GUI_CLICKED events simultaneously. We will add GUI_CLICKED event as separate. Thankyou :) Link to comment
