[SOLVED] How to load network plugin(sim version)
In my world, i want to use network_x64.dll like this: -extern_plugin network. Dut i can not load it because  of " bad  "network" plugin version 0x000400d 0x1000400d".
My Unigine version is:
#ifdef UNIGINE_DOUBLE
  #define UNIGINE_VERSION 0x1000400d
#else
  #define UNIGINE_VERSION 0x0000400d
#endif
What should i do that i can load the plugin? thanks
Link to post
  • 3 months later...
Unfortunately, Network plugin works only with float precision binaries.
can i make a double precision binaries with recompiling ?
Link to post
This is possible. However, we can not guarantee stable work in this case.
You need to modify <SDK>\source\plugins\Network\RakNet\source\SConscript file on line 59:
 if g_double:
  defines += ' USE_DOUBLE'
to:
 if g_double:
  defines += ' USE_DOUBLE UNIGINE_DOUBLE'
And rebuild Network plugin via scons double=1.
Link to post
  • 1 month later...
 if g_double:
to:
 if g_double:
Hi, i type  "scons double=1" on command in <SDK>\source\plugins\Network\RakNet\, but some errors have shown as shown in the picture. what can i do to solve it ?I have sent the error image in email.
Thank you~
Link to post
