anthony.liot Posted March 11, 2014 Share Posted March 11, 2014 Hi, I have some trouble with the Async class, I need to pass a parameter who is an array (Asset assets[0] where asset is an script object).When I call the runv I have an error Async::run(): unknown type of argument (string), I am not sure if the trouble is because I try to pass an array of internal object, but the error message is about the name of the function theorically and the function exist. My call is : ModulImportThread::asynchronous = new Async(); ModulImportThread::asynchronous.runv("Environment::loadAssetOthersFromSts", ModulImportThread::asset_list); Do you have any suggestion how I can do that ?? and may be will be nice to have runv function with other variable and keep the last parameter for the array.Tony Link to comment
unclebob Posted March 21, 2014 Share Posted March 21, 2014 Hi Anthony! Looks like it's a bug, thank you for this. If you look inside engine code you can notice that when you pass function as a string it'll try to search it by passing size of your array which is incorrect. int Async::run(const Variable &name,const Vector<Variable> &arguments) { ... if(name.getType() == Variable::STRING) { const char *function_name = name.getString(); if(interpreter->is_extern_function(function_name)) { ExternFunctionBase *extern_function = interpreter->getExternFunction(function_name,arguments.size()); ... } } So try to get function id in UnigineScript first and then call Async::callv(id,your_array). Link to comment
unclebob Posted March 21, 2014 Share Posted March 21, 2014 Will be fixed in the next SDK. Link to comment
anthony.liot Posted March 21, 2014 Author Share Posted March 21, 2014 Hi @unclebob I will wait the last SDK. Will be released soon ? Thanks Link to comment
