demostenes Posted February 15, 2014 Share Posted February 15, 2014 In this case I would really love to use multi mesh export: http://imageshack.com/a/img59/6351/jrk7.jpg But I cant, because objects have LODs. It would be very handy to automatically "group" meshes with same name and LOD suffix for multimesh export, currently I have to manualy select all lods and export one by one. 1 hour work instead of 5 seconds.... Link to comment
nat.harrold Posted February 17, 2014 Share Posted February 17, 2014 I agree. It is a solid suggestion. Though we would add: Checkbox (on export dialogue) so script can check for suffix "_lod" and auto group in mesh and node export. (So artist has choice) If export from pivot, all mesh _lods should revert to the master _lod0 or root objects pivot. Should root object be called "_lod0"? Link to comment
demostenes Posted February 17, 2014 Author Share Posted February 17, 2014 I agree. It is a solid suggestion. Though we would add: Checkbox (on export dialogue) so script can check for suffix "_lod" and auto group in mesh and node export. (So artist has choice) If export from pivot, all mesh _lods should revert to the master _lod0 or root objects pivot. Should root object be called "_lod0"? Optional check box would be great. Actually for me it is does not important if root is called _lod0 as long as such export works :) Link to comment
binstream Posted April 21, 2014 Share Posted April 21, 2014 At the moment we can recommend to extend a MaxScript utility: plugins/Max/UnigineExport/UnigineMenu.ms There are examples of batch export in the file. Link to comment
