[SOLVED] Properties List Items collapsed
Hello.
We have a property file with a lot of subproperties.
Everytime we open the file in the editor, ALL of the subproperties are expanded, which makes it very hard to handle, folding all of them.
Is there a way to open the properties, with all of them collapsed (closed)?
Cheers
Werner
Most probably this can be done by modifying Unigine Editor script code in data directory (though this means that you have to reapply your modifications for new sdk releases...)
Werner, relevant code for editor properties tree view folding is in <../data/core/editor/editor_properties.h>. Changing  function void update_properties() in line 251ff with something like the following code (fully untested) should supress folder expansion.
void update_properties() {
		properties.sort();
/* disable
		int hidden[];
		saveTreeBoxFolded(properties_tb,hidden);
		string items[];
		properties_tb.setCallbackEnabled(GUI_CHANGED,0);
		properties_tb.clear();
		foreach(string name; properties) {
			items.append(name,properties_tb.addItem(name));
		properties_tb.setCallbackEnabled(GUI_CHANGED,1);
		properties_tb.setCurrentItem(-1);
			Property property = engine.properties.findProperty(name);
			if(property == old_property) properties_tb.setCurrentItem(items[name]);
			Property parent = property.getParent();
			if(parent == NULL) properties_tb.setItemColor(items[name],color_green);
			else if(property.getNumChilds()) properties_tb.setItemColor(items[name],color_orange);
			if(parent == NULL || properties.find(parent.getName()) == -1) continue;
			properties_tb.setItemParent(items[name],items[parent.getName()]);
		if(properties_tb.getCurrentItem() == -1) update_view();
/* disable
		restoreTreeBoxFolded(properties_tb,hidden);
                // fold all tree items
                int items[0];
                treebox.getItems(items);
                foreach(int item; items) {
                     treebox.setItemFolded(item,1);
Hi.
Nice.
Thank you, will give it a try.
(Wouldnt this be good to have it in the properties file as a parameter? like folded='1')
All best. Werner
