steve.brodie Posted February 5, 2014 Share Posted February 5, 2014 We are trying to get an example of Webgl working but it appears that some key files are missing from the binary SDK. Is it possible that those could be included in the zip. Thanks Link to comment
steve.brodie Posted February 19, 2014 Author Share Posted February 19, 2014 Any word on these missing files. Thanks Link to comment
necris Posted February 21, 2014 Share Posted February 21, 2014 Steve, sorry for late response.We are working on webGL plugin right now. It will be fixed in next SDK update. Link to comment
anthony.liot Posted February 21, 2014 Share Posted February 21, 2014 Hi @Necris, do you enabled the asm_js with Unigine, the result are really impressive, just need a quick fix inside the freetype library.Other thing my advice it's use emscripten-fastcomp, that make the build of Unigine really faster.Tony Link to comment
binstream Posted April 21, 2014 Share Posted April 21, 2014 WebGL files are available in the recent update, but we don't plan to work on it until WebGL 2 will be a standard. Link to comment
Priyank.Jain2 Posted July 3, 2014 Share Posted July 3, 2014 (edited) I have latest source SDK (2014-06-04), but looks like some files/folders are still missing. Like "data\core\shaders\simple" and "data\core\materials\simple". As a result, I am unable to build example of webgl and unable to view some existing samples. Log snippet below: "Loading "samples/animation/animation_00.world" 49ms" main.html:37 "GLESShader::loadVertex(): error in "core/shaders/simple/mesh/vertex_base.shader" file" main.html:42 "defines: UNKNOWN,QUALITY_LOW,QUALITY_MEDIUM,MULTISAMPLE_0,USE_ALPHA_FADE,USE_REFLECTION,USE_DEFERRED,USE_PARALLAX,USE_RGB10A2,USE_PHONG_RIM,USE_ENVIRONMENT,USE_NORMALIZATION,USE_DIRECTIONAL_LIGHTMAPS,USE_SHADOW_KERNEL,OPENGLES,SHADING_LANGUAGE=0,BASE_AMBIENT,AMBIENT,OPACITY,MESH_SKINNED" main.html:42 Error: WebGL: linkProgram: this program doesn't have both a vertex shader and a fragment shader main.js:9239 "ERROR: too many uniformsGLESShader::compile(): can't link program" Just saw binstream's reply on my other thread regarding similar issue. Edited July 3, 2014 by Priyank.Jain2 Link to comment
