[SOLVED] How do I load mesh from .smesh via UnigineScript?
I'm totally confused now. I have a smesh file in "data/path/file.smesh" folder. How exactly do I add it into the via UnigineScript?
I tried using:
ObjectMeshSkinned nMesh = engine.editor.addNode("data/path/file.smesh");
but it said that it cannot convert pointer to Mesh. So I tried using a *ptr but it keeps reporting that it doesn't understand '*'.
So Then I tried:
ObjectMeshSkinned nMesh = new ObjectMeshSkinned ("data/path/file.smesh", 0);
It compiled but that doesn't seem to do anything. I don't see any new mesh both in world window and editor window. Totally stuck now. Much appreciate for any help I can have with this.
best, T_T
(ps.  I cannot believe you do not have any tutorial for adding mesh object through the script though.. I mean, wouldn't this be a good place to start your programming guide?)
As already stated in other thread: there is a simple example for ObjectSkinnedMesh including the required code for smesh file loading. If you don't want to invest this time for getting started, I don't think that other users of the forum are willing to invest their time on helping you
I've spending the whole day digging through samples to locate it actually. But it's very hard to look for something you don't know even where to start looking.  I've found and tried all things I could find in samples (as asked in my previous post) but I'm at my wit's end.
This is like you telling me to go learn french from a french book. To the native, it must be hard to understand why other couldn't figure it out. But as a customer in trouble, I'm telling you that it's very hard without all these basic coding tutorials.
So can someone kindly point me to the right explanation? T_T
Hello Killer.Penguin,
You can try to do it this way:
ObjectMeshSkinned nMesh = engine.editor.addNode(node_remove(new ObjectMeshSkinned("data/path/file.smesh")));
But keep in mind that the new object has no material assigned.
Oooh I think I might have tried something along that line but it didn't work...
I'll go try it again and let you know tomorrow.
Thx :)
ps. so we just keep using engine.editor class for all node adding? Is there any bad side effect to it?
Back to pointer issue... Unlike "engine.world.loadNode()" which directly ask for a file name, "engine.editor.addNode()" ask for a Node Class instead.
So, how exactly do I use "engine.editor.addNode()" to add a "<path>file.node" to the world? Currently I'm using:
Node nNode = engine.world.loadNode("<path>filename.node");
engine.editor.addNode(nNode);
Which seems to work, but I would suspect that it's redundantly wrong somehow.
There shouldn't be any problems if you use te following for adding node from the script:
In this case node is handled by editor script.
If you still have any problems with visibility, please, check the material assigned to the node.
