frustum Posted August 23, 2010 Share Posted August 23, 2010 Swizzled access to the user defined functions return value: vec3 foo() { return vec3(1.0f,2.0f,3.0f); } printf("%f %f\n",foo().x,foo()[0]); printf("%f %f\n",translate(1.0f,2.0f,3.0f).m23,translate(1.0f,2.0f,3.0f)[14]); Class construction by literal name: File file = new("File"); LightOmni light = new("LightOmni",vec4_one,vec3_one); Call destructor for all array elements and clear array: Foo array[] = ( new Foo(), new Foo() ); array.delete(); Add element into the vector after specified position: int array[] = ( 0,1 ); array.append(1,13); // 0,13,1 array.append(3,13); // 0,13,1,13 Manual casting of classes: class Foo { void foo() { } }; int foo = new Foo(); Foo(foo).foo(); // manually set of class type //foo.foo(); // compilation error Variable number of call() function arguments: int args[] = ("%s\n","hello world"); call("printf",args); // prints "hello world" Automatic memory management for extern classes: File file = class_manage(new File()); file = 0; // deletes file because of zero class references Check class type: File file = new File(); is_base_class("File",file); // returns 1 because File is File is_base_class("Stream",file); // returns 1 because Stream is a base class for File is_base_class("Socket",file); // returns 0 because Socket is not a base class for File Extended swizzlers: vec4 v = vec4(10.0f,11.0f,12.0f,13.0f); printf("%s\n",typeinfo(v.xyzw)); // prints "10 11 12 13" printf("%s\n",typeinfo(v.10zw)); // prints "1 0 12 13" printf("%s\n",typeinfo(v.xy10)); // prints "10 11 1 0" 2 Link to comment
alexei.garbuzenko Posted August 23, 2010 Share Posted August 23, 2010 To call base class parametrized constructor use fllowing constuct: class Foo // base class { Foo(vec3 vec) { .. } }; class Bar : Foo // derived class { Bar(vec3 vec) { __Foo__(vec); .. } }; Link to comment
