map: check existing value with key
I use map for save int values with string keys:
int listTable[];
idTextTable["key"] = 10;
When I want check if value is exists by key "key":
if (listTable["key"] != NULL)
 log.message("listTable[id]: " + listTable["key"]);
This is work only if "key" and value 10 added earlier. If I use that:
int listTable[];
this is cause to error. How I could check if value is exists by key? Thanks
int listTable[];
if (listTable.check("key") == 1)
The check() method checks for the existence of a key or index.
int listTable[];
idTextTable["key"] = NULL; // 0
if (listTable["key"] == NULL)
 log.message("key maps to NULL(0)");
The [] access operator accesses using key or index, without checking for existence.
Checking to see if the accessed location is NULL checks to see if the "key" is mapped to a value of NULL, not whether it exists or not.
Hope that helps! :)
