[SOLVED] Terrain Brush Radius
To increase brush radius you can edit max variable in Terrain::radius_el editline (line 66) in <SDK>/data/core/editor/editor_terrain.ui
Brush radius will affect the performance, so it is preferable to use 50 as a max value.
Hi there,
Is there any way to increase the radius beyond 50?
The sculpting takes way too long for a 8000 size map.
Thanks,
Andrew
Dont do sculpting by hand, but generate terrain in some 3rd party editor. And use brushes only for small tuning.
I have thought in the beginning I could do this as well..... but really no change. (we have about 100 squkm).
Use a heightmap, its easy, pleasing and quick.
Use the Edit Terrain afterwards for refining.
You can even export your Normal Maps and refine it, bring it back etc.
cheers.
Werner
