[SOLVED] Problem parsing application arguments in Windows
Hi all,
my problem is I'm not able to convert input parameters from command line arguments. This is the code sample:
#include <samples/systems/common/systems.h>
void update_scene() { ; }
void create_scene() {
	forloop(int i=0 ; engine.getNumArgs()) {
		if(engine.getArg(i) == "--msg") {
			log.message("param:%s", engine.getArg(i+1));
			break;
	return "Application arguments";
void clear_scene() {
If I run the sample with the following arguments:
main_x86.exe -engine_config ..\data\unigine.cfg -console_command "world_load samples\systems\arguments" --msg cañón
I get the wrong representation of the argument, so in the log file appears:
18:13:10 param:ca��n (instead of cañón)
I suppose it's because wndows input parameters are codified in a different way that Unigine interprets it (Utf-8)
How can I convert this string argument to Utf-8?
I don't have this problem in OSX and Linux because they always work in Utf-8.
Thanks in advance,
Iván.
