eugene.litvinov Posted December 2, 2010 Share Posted December 2, 2010 Hello. I working on mechanism, when player get an object, and it hover in front of camera (PlayerActor). When player is move or rotate view, object still in focus (in center of view). First of all, I used: PlayerActor player; Object mouseOverObject; player.addWorldChild(mouseOverObject); but in this manner I can't use physical behavior. Then I try use system from physics examples: when we add some force to body - this realization not appropriate cause object levitate some time (it's look not like we take object in hand). Then I use Joint (JointFixed look like most appropriate). I have some questions: 1. I use two bodies: body of picked object and body of camera. Then object moved at the camera, when I move camera. But joint not change it's position, when I rotate camera. 2. I try set void setRotation0(mat3 rotation) for update rotation of joint with camera rotation, but quat getRotation() return quat, how it could be converted from quad to mat3? Link to comment
eugene.litvinov Posted December 4, 2010 Author Share Posted December 4, 2010 for convertion quad to mat3 use function rotation. Link to comment
