sergey.pozhidaev Posted October 8, 2013 Share Posted October 8, 2013 on ObjectMesh & ObjectDynamic objects getIntersection does not work, mask and setintersection flags = 1 Link to comment
frustum Posted October 8, 2013 Share Posted October 8, 2013 ObjectDynamic doesn't have intersection code. You have to provide invisible intersection mesh inside ObjectMesh. Link to comment
sergey.pozhidaev Posted October 8, 2013 Author Share Posted October 8, 2013 i only want to create custom mesh with Unigine-pick system and modify it anytime ObjectMesh o = add_editor(new ObjectMesh(0)); o.addEmptySurface("surf0", 4, 6); o.setVertex(0,vec3(-1.5f,8,0),0); o.setVertex(1,vec3(-1.5f,1.5f,0),0); o.setVertex(2,vec3(-11,8,0),0); o.setVertex(3,vec3(-11,1.5f,0),0); o.setTexCoord(0,vec4(10,-6,0,0),0); o.setTexCoord(1,vec4(10,1,0,0),0); o.setTexCoord(2,vec4(0,-6,0,0),0); o.setTexCoord(3,vec4(0,1,0,0),0); o.setTangent(0,vec4(1,0,0.000015f,-1),0); o.setTangent(1,vec4(1,0,0.000015f,-1),0); o.setTangent(2,vec4(1,0,0.000015f,-1),0); o.setTangent(3,vec4(1,0,0.000015f,-1),0); vec3 norm = vec3(-0.000015f,-0.000015f,1); o.setNormal(0,norm,0); o.setNormal(1,norm,0); o.setNormal(2,norm,0); o.setNormal(3,norm,0); o.setIndex(0,2,0); o.setIndex(1,3,0); o.setIndex(2,0,0); o.setIndex(3,1,0); o.setIndex(4,0,0); o.setIndex(5,3,0); o.setMaterial("mesh_base","*"); o.setProperty("surface_base","*"); o.setEnabled(1,0); o.setIntersectionMask(1,0); o.setIntersection(1,0); and then i use: Vec3 p0,p1; Unigine::getPlayerMouseDirection(p0,p1); int ret[0]; Object o = engine.world.getIntersection(p0,p1,1,ret); but unigine does not detect my custom mesh Link to comment
frustum Posted October 8, 2013 Share Posted October 8, 2013 Call "o.updateSurfaces();" after mesh creation. Link to comment
sergey.pozhidaev Posted October 8, 2013 Author Share Posted October 8, 2013 i did it :D "unknown ObjectMesh class member updateSurfaces();" Link to comment
frustum Posted October 8, 2013 Share Posted October 8, 2013 "ObjectMesh::updateSurfaces" method should exist in the latest SDK update. Link to comment
sergey.pozhidaev Posted October 8, 2013 Author Share Posted October 8, 2013 how set bounds of ObjectMesh? it is not itersecting by getIntersection, how get intersection by Unigine on Custom ObjectMesh? or some other mesh, i need construct one mesh and get intersection by Unigine getIntersection, or i have to write own intersector for custom meshes? Link to comment
sergey.pozhidaev Posted October 9, 2013 Author Share Posted October 9, 2013 ok, i know what is my problem: need to update bounds of custom mesh, but what i need to do for that? Link to comment
sergey.pozhidaev Posted October 9, 2013 Author Share Posted October 9, 2013 ok, i`l use ObjectMeshDynamic - it works fine , because it consists updateBounds(); Link to comment
frustum Posted October 9, 2013 Share Posted October 9, 2013 Call "o.setSurfaceTransform(mat4_identity,0);" to recalculate bounds. ObjectMesh is much more effective for intersection and collision than ObjectMeshDynamic. Link to comment
sergey.pozhidaev Posted October 9, 2013 Author Share Posted October 9, 2013 bounds recalced, but still no intersection :D , something else? on ObjectMeshDynamic it works Link to comment
unclebob Posted November 8, 2013 Share Posted November 8, 2013 Hi Sergey! Sorry for late reply, have you still issuing this problem? I've modified mesh_01 example in samples/objects folder and added intersection test so it might help you. /* */ void update_scene() { while(1) { float ifps = engine.game.getIFps() * 0.1f; foreach(ObjectMesh mesh, i = 0; meshes; i++) { mesh.setWorldTransform(Mat4(mesh.getTransform() * quat(1.0f,1.0f,1.0f,ifps * i))); } vec3 p0,p1; Unigine::getPlayerMouseDirection(p0,p1); int ret[0]; Object o = engine.world.getIntersection(p0,p1,1,ret); if(o != NULL) { forloop(int i = 0; o.getNumSurfaces()) { o.setMaterialParameter("diffuse_color",vec4(1.0f,0.0f,0.0f,1.0f),i); o.setMaterialTexture("diffuse","",i); } } wait; } } Link to comment
