frustum Posted September 21, 2013 Posted September 21, 2013 Java style derived classes: class Foo { void foo() { printf("base\n"); } }; Foo f = new Foo() { void foo() { printf("derived\n"); } }; f.foo(); Fast type based branching:switch(typeid(variable)) { case typeid(int): printf("int\n"); break; case typeid(float): printf("float\n"); break; case typeid(string): printf("string\n"); break; } Function identifiers:int id = get_function("sin"); call(id,1.0f); class Foo { void foo() { } }; int id = get_function("Foo::foo"); Foo foo = new Foo(); foo.call(id); Access to function return value elements and swizzles:vec3 foo() { return vec3(1.0f,2.0f,3.0f); } printf("%f %f\n",foo().x,foo()[0]); printf("%f %f\n",translate(1.0f,2.0f,3.0f).m23,translate(1.0f,2.0f,3.0f)[14]); String based operator "new":File file = new("File"); LightOmni light = new("LightOmni",vec4_one,vec3_one); Delete all internal elements and clear the array:Foo array[] = ( new Foo() ); array.delete(); Append an element into specified position:int array[] = ( 0,1 ); array.append(1,13); // 0,13,1 array.append(3,13); // 0,13,1,13 Find a map element:int array[] = ( -1:-1, 0:0, 1:1 ); array.find(-1); // returns -1 and it's correct array.find(2); // returns -1 and it's wrong array.find(2,-13); // returns -13 as a workarround Safe array element getter.int array[] = ( -1:-1, 0:0, 1:1 ); array.check(-1,-13); // returns -1 array.check(-2,-13); // returns -13 Class casting:class Foo { void foo() { } }; int foo = new Foo(); Foo(foo).foo(); // Manually cast to type //foo.foo(); // incorrect because foo is int Variable number arguments of call and thread methods:int args[] = ("%s\n","hello world"); call("printf",args); // prints "hello world" Ref-count based memory management for external classes:File file = class_manage(new File()); file = 0; // file will be deleted when ref count is zero Functions inlining:void get() { return a; } // automatic functions inlining void set(int b) { a = b; } User class operator[] overloading:class Foo { mat4 m; void __set__(Foo f,int index,int value) { f.m[index] = value; } int __get__(Foo f,int index) { return f.m[index]; } }; Foo f = new Foo(); f[0] = 10; f[1] = f[0]; printf("%g %g\n",f[0],f[1]); // prints "10 10" Extended swizzles:vec4 v = vec4(10.0f,11.0f,12.0f,13.0f); printf("%s\n",typeinfo(v.xyzw)); // prints "10 11 12 13" printf("%s\n",typeinfo(v.10zw)); // prints "1 0 12 13" printf("%s\n",typeinfo(v.xy10)); // prints "10 11 1 0" New typeid argument type:int a = 1; if(typeid(a) == typeid(int)) printf("int\n"); New classid statement:class Foo { }; if(classid(new Foo()) == classid(Foo)) printf("Foo\n"); Check class inheritance:File file = new File(); is_base_class("File",file); // return 1 bcz File is File is_base_class("Stream",file); // return 1 bcz Stream is a base class for File is_base_class("Socket",file); // return 0 bcz Socket is not a base class for FileNew syntax of is_base_class() function:is_base_class(classid(File),file); // return 1 bcz File is File is_base_class(classid(Stream),file); // return 1 bcz Stream is a base class for File is_base_class(classid(Socket),file); // return 0 bcz Socket is not a base class for File Super keyword:class Foo { void foo() { printf("base\n"); } }; class Bar { void foo() { printf("derived\n"); } void bar() { super.foo(); // prints "base" this.foo(); // prints "derived" } }; Bar bar = new Bar(); bar.bar(); Interface class support and virtual function declaration:class Interface { void update() = 0; }; class Foo { void foo() = 0; }; class Bar : Foo, Interface { void update() { printf("Bar::update(): called\n"); } }; class Baz : Interface { void update() { printf("Baz::update(): called\n"); } }; Interface interfaces[0]; interfaces.append(new Bar()); interfaces.append(new Baz()); foreach(Interface i; interfaces) { i.update(); } // Bar::update(): called // Baz::update(): called The current thread identifier:printf("%d\n",get_thread()); New array functions: int a[] = (1,2,3,4); int b[] = (5,6,7,8); int c[] = (9,10,11,12); int d[] = (1:1.0,2:2.0,3:3.0); a.append(b,1,2); a.remove(0,6); a.append(c,1,2); printf("%s\n",a.typeinfo()); printf("%s\n",b.typeinfo()); printf("%s\n",c.typeinfo()); printf("%s\n",d.typeinfo()); Fast class based branching:class Foo { }; class Bar { }; void foo(int a) { switch(classid(a)) { case classid(Foo): printf("Foo\n"); break; case classid(Bar): printf("Bar\n"); break; case classid(File): printf("File\n"); break; } } foo(new Foo()); foo(new Bar()); foo(new File()); printf("%d %d\n",classid(new Foo()),classid(Foo)); printf("%d %d\n",classid(new Bar()),classid(Bar)); printf("%d %d\n",classid(new File()),classid(File)); Variable referencing:class Foo { int v; }; void foo(int &v) { if(v) printf("%d\n",v); v = 13; } { int v = 0; foo(v); foo(v); } { Foo f = new Foo(); foo(f.v); foo(f.v); } { int v[] = (0); foo(v[0]); foo(v[0]); } { Foo f[] = (new Foo()); foo(f[0].v); foo(f[0].v); }
frustum Posted September 21, 2013 Author Posted September 21, 2013 This is our internal article with scripting TipsTricks.PS: "super" keyword and interface classes will be available in the next SDK update.
steve3d Posted September 22, 2013 Posted September 22, 2013 Thank you for this great tips & tricks :D
manuel.gysin Posted October 17, 2013 Posted October 17, 2013 class Bar : Foo, Interface { void update() { printf("Bar::update(): called\n"); } }; Is multiple inheritance supported by now? The documentation says it is not. There are some peculiarities of the class inheritance in UnigineScript: Multiple inheritance is not supported.
necris Posted October 17, 2013 Posted October 17, 2013 Manuel, Is multiple inheritance supported by now? The documentation says it is not. Yep, it's completely supported now. Documentation will be updated soon.
manuel.gysin Posted October 17, 2013 Posted October 17, 2013 Manuel, Yep, it's completely supported now. Documentation will be updated soon. Brilliant! Thanks. :)
lars.saalbach Posted October 18, 2013 Posted October 18, 2013 Thats realy awesome stuff! :)Looking forward to test it this evening!
alexey.egorov Posted February 11, 2014 Posted February 11, 2014 Alexander, please include details about reflection and attributes, this is the awesomest power of unigine script) now we are creating no-headache automatic gui generation based on this features.
manuel.gysin Posted November 30, 2014 Posted November 30, 2014 Hello, Maybe someone can use this too. This will slightly modify the extern_info.h in such a way, that everything should work with an IDE. Mainly the engine.* commands are mapped to a class with sub classes, this way you have all methods. #!/bin/python # General values subclass = {} shortones = [] # Normal unigne classes default = '' # Special engine class output = 'class engine {\n' # Open file and read all lines with open('extern_info.h') as f: content = f.readlines() # Check each line and save it to the right place for line in content: # For lines which contains engine. we have to do the magic if "engine." in line: # Split line sub_command = line.split(".") # There are two type of lines, lines with sub classes and normal methods if len(sub_command) >=3: # Get sub class sub = sub_command[1] # Only append if not already known if sub not in subclass: subclass[sub] = [] commandMap = subclass[sub] commandMap.append(sub_command[0].replace('engine','') + '' +sub_command[2]) else: commandMap = subclass[sub] commandMap.append(sub_command[0].replace('engine','') + '' +sub_command[2]) else: shortones.append(sub_command[1]) else: default += line # Add normal methods for method in shortones: output += '\t' + method # Create engine class with all sub classes and methods for sub in subclass: # Create an instance of each sub class output += '\t' + sub + ' ' + sub + ';\n' # Define class output += '\tclass ' + sub + ' {\n' # Add methods for entry in subclass[sub]: output += '\t\t' + entry output += '\t};\n' output += '}' # Add the default classes output = default + output # Write and save f = open('extern.h', 'w') f.write(output) f.close()
