ivan.cuevas Posted July 26, 2013 Share Posted July 26, 2013 Hi, I have a Unigine::Widgets::Window with a virtual monitor that it's displaying the same image as main viewport. I already done using a WidgetSpriteViewport and the engine.game player. I suspect I'm rendering the same image twice. I wonder if there is another way more efficent to do this. Something similar to image_00 sample but instead of calling engine.render.renderImage2D(), using the already rendered image created by main viewport. Thanks in advance, Iván. Link to comment
ulf.schroeter Posted July 26, 2013 Share Posted July 26, 2013 just brainstorming without too much of thinking: maybe new unigine custom post-processing shader could be used to copy final rendered main viewport image to a (smaller) GPU-side material texture that can be used on the next frame for gui viewport rendering. 1-frame-delay shouldn't be a problem in most cases. not sure if this is actually possible, but maybe a starting point for some experimenting Link to comment
frustum Posted September 8, 2013 Share Posted September 8, 2013 If you don't need the rendering inside the main window just call engine.render.setEnabled(0). Or as an option you can create a custom App which will be replicate the final image into the external one. Inside Unigine API you can find a ready to use stack of textures, render targets and shaders. Link to comment
ivan.cuevas Posted September 9, 2013 Author Share Posted September 9, 2013 I thought there might be an easier solution for this, at the moment I need to spend time in another modules of the application. Thanks for your advices guys. Link to comment
